Question about Garmin GPS 12XL GPS Receiver
I left my unit on board for all the winter and now the display shows horizontal lines blank and many informations are very difficult to be read.In addition there is no link to the autopilot. I opened the unit and found a green wire disconnected from (I suppose) a disk-like on the upper part which has yet a soldered wire: it seems a battery, isn't it? Is it possible to do something to repair,since other functions work well?Thanks in advance
  • 35 Answers
SOURCE: Display
The problem is a physical one, not a software issue.
I assume some sort of loose connection(s) at the screen or failure in the hardware.
Have been reluctant to dis-assemble without advice/guidance from someone that has experienced and solved the problem.
Can not update software as no link cable comes with unit.
Recently attempted to construct one ( found directions online for home made version) but needed a different type of wire than I had available at the time. (cost to purchase one from Garmin prohibitive for my uses) I have repaired an unresponsive Dell Axim x5 screen by dis-assembling and placing tape over a burnt ribbon connector so I am not afraid to work on the unit provided some success is possible. Not knowledgeable enough to just look for something that might not be apparent to the untrained eye with the risk of damaging the unit further. The unit is usable just difficult to read.
Posted on Apr 01, 2008
  • 18 Answers
SOURCE: Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
Posted on May 09, 2008
kiyro
  • 4 Answers
SOURCE: white lines across screen
normally RCA"S are common with this problem. Some of them have a knob in the back the adjust the brightness. This will sometime get rid of the lines. I did it to my RCA and it worked like a charm.
Posted on May 22, 2008
SOURCE: Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Posted on Oct 06, 2008
  • 32 Answers
SOURCE: I have a Garmin 45 handheld gps that has the
we have the digitizer for all tomtom and garmin nuvi series GPS,pls contact me if you still need the digitizer and the LCD screen.
kingyijin@hotmail.com
Posted on Sep 16, 2009
How do i fix the horizontal lines on my tv they are upper left and lower left only
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | LG LM6700 47 in. Cinema 3D Smart TV
How do I fix a Sony TV that starts then screen goes blank
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 24, 2015 | Sony Televison & Video
I have Videocon 32" LCD( VDL32HBA-FLA ) which got screen blank with vertical / horizontal lines and no osd menu
The T'Con board should be suspected. This is a common fault to most brand of LCD TVs. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 29, 2012 | iLO 3200 32 in. LCD Television
Toshiba 57LX177: Right side of screen darker than left
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
Feb 21, 2009 | Toshiba 57LX177 Television
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
'03 BMW 530I Radio
I think replacement of the face unit is needed. the LED's that illuminate my have been pixelated through sun exposure. Replacement necessary.
Feb 13, 2008 | Car Audio & Video
Display
Update the unit software and please report back if this fixes the problem.
May 30, 2007 | Garmin eTrex GPS Receiver
Horizontal line
A horizontal line means that the verticle deflection circuit is not operating. Take it to a TV repair shop this is not a difficult fix for a tv tech
Nov 28, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Garmin GPS 12XL GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
