Question about RIM BlackBerry Pearl Smartphone
My blackberry curve 8520 wont turn on, will not charge up only a red line through the battery symbol
Bubbabear64
  • 2794 Answers
SOURCE: blackberry wont turn on just shows red line through battery
Sounds like the display. There is a warranty on the unit. Contact your provider to find out what your service and replacement options are.
Posted on Dec 18, 2008
SOURCE: Blackberry Curve has a battery icon w/ red line through it
Try removing the battery for about 20 seconds and then put it back in and restart the phone. This is a form of a hard reset but it will not erase anything.
Posted on Jul 28, 2009
  • 5 Answers
SOURCE: Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
Posted on Aug 20, 2009
SOURCE: I have a blackberry Curve 8310 and the screen is
me too...whats the problem and whats the solution please??
Posted on Sep 17, 2009
just put a piece of paper on the top of the battery (the part where u push it down) it shows the battery with a red line slashed across because its too loose...
it worked for me!
Posted on Nov 01, 2009
Bb 8520 comes up with charging sign with a red cross across on the screen. help!!!! Options
it happens when ur bb battery is damaged if u change ur battery u will not face that problem
Feb 13, 2013 | RIM BlackBerry Curve 8520 Smartphone
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Blackberry curve 8520 wont turn on, no red light wont charge or do nothing when the usb is inserted
maybe a bad cord. if it charges normal on the charger then it needs to be setup so it will charge thru the usb
Jul 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
How did i want to know that my blackberry curve 8520 is charging?is there any signal?
There's a symbol of the battery on the top left corner. When you plug in the charger and turn it on, note the changes in the battery. It will show that it's filling. When the indicator steadies itself at the maximum point, it indicates that the battery is full.
Hope this will help. If you need any more assistance, don't hesitate to come back to us. Else, if the problem is solved, please DO ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 06, 2010 | RIM Holster For BlackBerry Curve 8520
BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
May 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
My 8520 curve just shut off and will not power up. Full charge, phone 1 week old
My Blackberry 8520 just shut itself down and when I try to turn it back on nothing happens but when I put it into the wall charger the red LED light comes on and a charging symbol but still doesnt switch on.
Ive tried of mulitiple occasions taking out the battery and rebooting it but still no sign of any life?
Any Idea's?
Feb 12, 2010 | RIM BlackBerry Curve 8520 Smartphone
Been on charge all night. wont turn on and has rotating black clock in centre of a blank screen
my blackberry curve went dead and when i placed it to charge for the entire night i tried to turn on the phone and it wont turn on but there is a red light on the phone for a few minutes .... what can i do?
Nov 05, 2009 | RIM BlackBerry Curve 8520 Smartphone
Blackberry wont turn on just shows red line through battery
Dec 18, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Pearl Smartphone Logo
44 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
