Question about Dewalt 18V, Heavy Duty, Variable Speed, Cordless, Jig Saw Kit
How do i change the blade in a cordless var.speed jig saw? I just got a dewalt jig saw but i don't knwow...it might be broken...i can't change the blade...or i don't know how...can you help me? By the way...is a used one...thanks...
  • 132 Answers
SOURCE: JIG SAW 1584AVS Blade not locking in
you have to push the blade all the way in sideways first after this turn blade straight then tighten the holding scew
Posted on Nov 09, 2008
rowdy45176
  • 2176 Answers
SOURCE: dewalt 10 inch portable table saw blade height adjustment very st
What I would do is clean area with air (wear safety glasses) then I use a spray type of dry lubricant on the threads and also the plates that the motor slides on. You can also use WD-40 in a pinch. Hope this helps
Posted on Dec 10, 2008
muttandjeff
  • 359 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Posted on Feb 23, 2009
joboo1
  • 257 Answers
SOURCE: Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Posted on Mar 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
Posted on Mar 22, 2009
How do I get a broken blade out of Dewalt DC330?
Do the same procedure on how you installed the blade.
Sep 14, 2014 | Dewalt 18v 18 Volt Cordless Xrp Jig Saw...
Got a dewalt dw321k. Bought it new years ago. Cannot get a blade into it at all. Undone the top but still can't get blade in. Any ideas??????
These t-top blades are not obvious in how they fit, but fortunately they have been around long enough that there are lots of people that can help you. It may be humiliating, but just take the saw to any hardware or home-improvement store and ask somebody there to show you how it works---- or you could save face by leaving your saw at home and just asking for help with one on display! Just about any saw that uses this style of blade (which is most of them now) will work the same way, so you don't even have to find your exact same model. Good luck.
Oct 14, 2012 | Dewalt DW321K Heavy Duty Variable Speed...
How to use the splintering insert for the de330 jigsaw
The only reference to the insert is in the manual for your jig saw. If you don't have it you can download one from the Dewalt service website at http://servicenet.dewalt.com/. Find your tool by searching for your model number in the Find Parts box. The manual doesn't go into very much detail but there are instructions on when to and when not to use it and a picture of it installed on the saw.
Sep 19, 2012 | Dewalt 18 VOLT CORDLESS JIG SAW MODEL...
Motor goes round in the dewalt but there is no drive.
check bearing and brushes, this was my problem on my SKIL 4280.
Mar 28, 2010 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Blade comes out while sawing
I have used the same tool. Make sure that the blade release/ hold tab is engaged. Maybe the return spring is fouled or stuck. Try some lubricant.
Jun 20, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Jig Saws safety problems
look out for the following safety features: * Safety switch or lock off button * Some saws have a soft start feature that starts the saw at a slower speed. * Blade guard that shields you during use
Aug 27, 2008 | Dewalt DC6KTJA 18v. Xrp Super 6 - Kit...
Dewalt 18V, Heavy Duty, Variable Speed, Cordless, Jig Saw Kit Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
