Hi our tv just won't turn on any ideas? We have pluged it into another power source and checked the cable . the cable is fine. thanks
  • 4,889 Answers
If it does not turn on then it is usually due to a component level failure on one of the boards. Does the LED at the front blink or just stay on? Does it make a clicking noise like its trying to turn on when you press the power button on your remote? Also please let me know the make and model of the tv. Please provide this info so that I can offer you insights into the cause of the problem and how to fix it.
Sai.
Posted on May 28, 2011
  • 2 more comments
  • ms_mpsorge May 29, 2011
    the led light does not come on and the power button is working I have tried the remote and that didn't work either. My husband pulled it apart and found that a fuse was blown so we replaced it then it turned on for a second then blew both fuses? any idea? he thinks we need to replace the board but not sure if this may cost more than buying a new tv?
    thanks
  • eagle338
    eagle338 May 29, 2011
    The cost of the board depends on the make and model of the tv. Please get me this info and I will tell you how much a replacement costs
    hi,
    its a sharp aquos lc-26af3x about 5 years old. it doesnt have a hd turner in it.
  • eagle338
    For a set of this size, the power supply would hardly costs about 50-75$. Please get me the part number off the board so that I can find you a replacement
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
My printer won't turn on
Hi
Either the power source has issues or the power jack on printer has gone bad or printer's main board has issues.
Verify that the electrical connections and outlet are functioning:-
Unplug the power cable or power module from the electrical outlet.Unplug the power cable or power module cable from any power strips or surge suppressors.If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it back into the power module.Unplug the power cable or power module from the back of the product.Wait at least 30 seconds, and then plug in the power cable or power module into the electrical outlet.Plug the power cable or power module back into the product.Turn the product on.
If this doesnt help, take the printer to another room and plug it in another power source.
If this doesnt help, use a multimeter to check if adapter is giving out right voltage.
If adapter and power source are fine, then your printer has a hardware issue and needs to be repaired by Canon.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Have a samsung 32in flatscreen that i unpluged and when i pluged it back in it will not come on
hi just unplug again don't use for an hour to discharge excessive voltage store at the power supply usually at the primary capacitor and also to reset the processor which turn on/off the circuit.while you are waiting to discharge the voltage check the power outlet try to plug other equipment just to let you know if the power source is good. now if it is present try to plug and turn on the unit observe if it is working.if still won't power on you will need to open the back cover keep the screw not to loose check first blown fuse at the power supply if no light indicator at the front panel when you turn on the unit it was power supply failure because no stand by supply. check bulged capacitor replace with branded parts use with high temperature rating capacity 105c.check also other obvious defective part. you can order parts at parts.digikey.com. hope it will help you thanks for choosing the fixya good luck.
Jun 24, 2011 | Samsung Televison & Video
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
