Question about Fedders A6X05F2D Air Conditioner
Have old fedders a/c and heater. Seems to rub on something when using and makes noise. Need to remove front or back cover to see what is making noise. Can't find anyway to remove either cover. Please help. Have a great day!
  • 413 Answers
All depends how old. The 70's and 80's models slid out of the case. If this is what you have, take the front off and slide the unit out of the case. If it had screws to take out, they would be around the bottom of the unit.
Posted on May 28, 2011
My front passenger wheel makes a rubbing noise at 50 mph
You just need to have a mechanic or someone look at the front end. Has it been happening long enough to cause any odd tire wear on the tire? If the front end alignment is off, you could certainly get a lot more road noise, but even a badly worn tire would cause some noise.
If the tire is actually rubbing against something, and you hear it at 50 mph, that seems to indicate badly worn suspension parts- like ball joints or struts...so you should consider a good front end alignment shop and tell them the condition. They can check the tires and the front end as well. A reputable shop would check all that anyway, to make sure that the alignment job will actually keep the front end true.
Mar 30, 2015 | Cars & Trucks
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
How to determine WHat is making the squeeling noise front outside of drum is worn like something is rubbing how do u look inside dryer it is fully enclosed
you will half to disassemble the unit by removing the screws on the back of the unit cover, place all the screws and bits and things in a box or something you won`t lose them, you can now use a flash-light with the unit running and observe the location of the sound you will likely see what is causing the noise.
Apr 15, 2012 | Dryers
Front passenger wheel makes a rubbing noise while
1) Wheel mis-aligned.
2) Suspension failure.
3) Shot bearing.
4) Inner wheel arch cover come adrift.
5) Something stuck in wheel arch.
Jul 04, 2010 | 2004 Kia Optima
My dryer makes a weird noise when running, kinda like the drum is rubbing against something, could that be a worn belt?
depending on the make and model of the machine the drum glides or rollers need replacing,to accomplish this you need to remove the front cover by removing toe kick panel screws and lifting up on cover,you get instructions with the glides or rollers on replacement when you buy them
Jan 23, 2010 | Dryers
Timing belt
what sort of noise is it a rubbing noise?
Dec 30, 2008 | 2000 Toyota RAV4
I makes a very loud noise
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
Jun 02, 2008 | Heating & Cooling
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Dropped drum
probable that the bearings have collapsed. remove back panel.undo wiring to heater and stats and make a note of where it goes. remove back plate of the tub assemby held by a clamp right round. drum andback plate then come out complete. take off pulley and put back bolt in shaft. tap bolt and you should be able to knock drum from backplate. you can then check bearings. you will need to replace bearings, lip seal and backplate seal.parts are not too expensive. check also condition of journal lip seal runs on. this must be in good condition.
May 07, 2007 | Siemens WFXD8400UC Front Load Washer
Fedders A6X05F2D Air Conditioner Logo
145 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
