Question about Hampton Bay Sidewinder 04890 Ceiling Fan
What kind of bulb is used for the Sidewinder fan? Description says 100 w Halogen, but the one I purchased (Philips Halogen Mini-Can, 100w) notes: "These lamps should not be used in ceiling fans".
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
SOURCE: light bulb socket uses intermediate base bulbs, not standard bulbs
I found the solution on the web. The only place it looks like that has this adapter is voss lighting. Here is a link to the adapter. http://www.vosslighting.com/storefrontB2BWEB/itemdetail.do?action=prepare_detail&itm_id=18159&itm_index=7
Posted on Nov 11, 2008
  • 25 Answers
SOURCE: need a ceiling fan hanger bracket for 12/6 pitch roof (ceiling).
cut a wood shim.
Posted on Jan 15, 2009
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
  • 75 Answers
SOURCE: Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Posted on Apr 26, 2009
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
How much light will 1 100W mini-can halogen bulb provide
check the packaging or contact the mfg.
Jan 18, 2015 | Cars & Trucks
Minka aire viper ceiling fan bulb
1- 100 watt mini can halogen.
Sep 03, 2014 | Dryers
BULB REPLACEMENT
I spoke with Harbor Breeze and finally received the answer. To get to the bulb, you need to push up slightly on the glass globe only. Not the metal ring around the glass. Then a slight turn counter-clockwise will allow the glass to drop down. It's a short 100W halogen bulb that's readily available at the hardware store. Also, in case you call Harbor Breeze, the item number for the LGF fan is #77461.
May 26, 2013 | Dryers
I have a model 763RLN where the instructions indicate a max.100W bulb but does not indicate the type of bulb. Is it a special type ?
That is possible,but usually they refer to a regular incondescent bulb with a filament.Screw in type.
You may use a CFL in there,easily. 27 W.
Warm white or cool white one.
100 W. bulbs should be not available,soon.
Jan 18, 2013 | Broan-NuTone N-763RLN Combination Light...
How to remove the glass cover on a 5tv52whd ceiling fan and where i can buy the bulb
Regards, Tony
May 11, 2011 | Monte Carlo 5DI52WHD Discus White Ceiling...
Need to change bulb on harbor breexe LGF-1 ceiling fan but can't figure out how to get to bulb?
Mar 19, 2011 | Heating & Cooling
How do I change the light bulb on the Harbor Breeze 52" Avian Brushed Nickel? specific directions please
I'm trying to change mine too. I can't figure out how to get the glass off it even.
Nov 29, 2010 | Heating & Cooling
How do you remove and replace an R7s halogen light bulb from its housing.? It looks like it shoul just push in at one end and release at the other, but does not seem to move far enough. Don't want to break...
Usually one side of the housing is fix, the other can be moved about 3-7mm. The whole ceramic body holding one sight of the bulb:
However different manufacture may have different designs, but this one is pretty common.
Feb 04, 2010 | Kitchen Appliances - Others
Palm beach 48"
Me too. I went back to Home Depot. They gave to me the phone number for Hampton Bay - 1-877-527-0313. I will call them tomorrow after they open to see what the deal is. it looks to me like the JDE11 is a mini-candelabra base. The lady in the fans at Home Depot said that all of the light kits were changing to the smaller based halogen lights. BUT, you'd think that they'd carry the light bulbs that have to go in the light kits they sell!!!
May 12, 2008 | Hampton Bay 48 In. Palm Beach in Textured...
Hampton Bay Sidewinder 04890 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
