Question about Sport & Outdoor - Others
Spooling reel - Sport & Outdoor - Others
  • Wesley Gardner
    Wesley Gardner May 28, 2011
    are you wanting to know how to spool a reel?
  • 659 Answers
If you are wanting to Learn how to Spool a Reel Properly this is one video I like.
Posted on May 28, 2011
I have the 1276sli abumatic spincast reel. The issue is when am reeling the line in there is bump in the handle always at bottom as i crank the line in under load.
Hey michael,
Sometime when you add line to a spincast reel, where you tie the knot and wind line onto the reel, it makes a bump in the spool, this "bump" in the spool sometimes hits inside the reel everytime it makes a rotation....
May 18, 2017 | Fishing
How do play both sides if what looks like a reel to reel tape that has a side 1 and side 2 ? My Akai 1722II does not have auto reverse . Thanks
You take the spools off and put the right spool on the left and the left on the right.
The link also explains, but i started on reel to reel in the late 60s. :>)
how do play both sides if what looks like reel to reel tape Google Search
Good video here
Reel to Reel Basics
Apr 25, 2017 | Akai Audio Players & Recorders
How to take reel apart to reload line
Hi Karen:
If this is a fishing reel, pull off the old line into a plastic bag or wind it on to an old spool so it can be safely discarded. Tie the new line on to the reel, and wind the new line on.
There used to be a closed face spinning reel that you would unscrew the face cover to access the spool.
If this is a weed eater, grass whip, some of the older units had a threaded centre with a left hand thread. Once unscrewed, the spool lifted off and you could wind on the new cutting cord.
Happy fishing, or gardening.
May 14, 2015 | Sport & Outdoor - Others
How do you put line on a magda pro star reel
Mount your reel on your rod. Run the line from your filler spool thrthrough the bottom guide of your rod. Pass the line througo the line guide on your reel and tie your line to your reel using an arbor knot. Put a pencil or dowel rod through your filier spool and have someone hold light tension on the spool as you reel line onto your reel.
Aug 03, 2014 | Okuma Magda Pro Linecounter Magda Pro...
Proper installation of fishing line
it needs to go on the reels spool in the opposite direction to the way its on the lines spool ,this will take all the twists out of the line when its on the reels spool
Apr 07, 2012 | Sport & Outdoor - Others
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How do you cast the reel so the spool dosent continue to unwind after the cast
On the side of the reel there is a knob that you adjust for the spooling.As a rule of thumb you adjust it so when you have a lure on,click the release button and let it spool out,it will only drop about 4 feet.Now! tighten it a fraction.Start casting and it will not go very far.Just before the lure hits the water,you put your thumb on the spool.Hard at first and then less as you get used to it.You can then adjust the spooling knob to go a bit further every time.You use your thumb on the spool to adjust the last 10 feet of line.Use a lure with no hooks on it to practise.It's called a plug.Hope this helps and you reel in the big one's
Sep 21, 2010 | Penn 320GT2 Graphite Levelwind...
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
Mar 17, 2009 | Shakespeare Agility Spinning Reel 6825
Sport & Outdoor - Others Logo
64 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
