Paper getting jammed of my canon mx330 printer
    Problem Solver:
  • 22 Answers
Clear and clean the paper path, while verifyeng the rollers.
Posted on May 28, 2011
Canon MX330 paper output slot has paper jam error. How to clean sensor
I just solve the problem and it's pretty simple. Just turn off the printer and put paper on the printer, then you turn it on and make sure the paper goes out from the other side; and done the warning message disappear (if the paper don't go inside the printer force it to go inside).
Mar 11, 2012 | Canon PIXMA MX330 Office All In One...
Paper jam
open the printer from the back to clear the paper jam
Jan 28, 2011 | Canon PIXMA MX330 Multifunction InkJet...
MX330 Printer jams continually - rollers won't grab the paper
If it's less than one year old, it's under warranty. Take it to a Canon authorized service centre and they will fix it for free (warranty). You can find a service centre by contacting Canon - go to their website.
If it's more than one year old, try this:
Clean the rubber tire(s) with rubbing alcohol. If still no good, try gently scuffing the surface of the rubber with an emery board or some sandpaper. This may bring back the surface of the rubber so it will grab the paper. If stll no good, replace the printer, as a repair may cost almost as much as a new printer.
Hope this helps!
Regards,
Joe
Jan 02, 2011 | Canon PIXMA MX330 Multifunction InkJet...
Canon PIXMA MX330 multifunction printer. I get a lot of faxes. Is there a way to save ink & paper by having all faxes come in without printing them & just putting them to memory & review them...
unfortunatly not!The m/c will print each and every fax!I can suggest getting a fax to email nr and recieve the faxes on your pc and then printing what u need!Memory does keep about 258 pages depending on the coverage on the pages!
Feb 22, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Oct 15, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
My printer grabs the paper sideways and feeds it that way then gets jammed or prints crinkled or sideways
Sounds like my Canon MX330... It's a mfg defect... I guess I now know why they were cheap at Factory Direct.. ***
Jul 04, 2009 | Canon Office Equipment & Supplies
k24674
jasbo
jasbo
