Question about Tissot T-Touch T33159851 Wrist Watch
I have a Tissot Expert Pilot. The display is flashing between the date and an error message(6AEE). How do I stopt it?
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Apr 22, 2017 | Tissot Watches
Tissot classic xxl date issues
I do not think there is anything you can to it to make it change date at exactly 00:00 hours (your time). Unless you want to consider this a major defect and send it for repairs.
In my opinion it is an idiosyncrasy that one can live with.
Dec 12, 2013 | Tissot Watches
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
The digital time display and the hands display don't match
You can try to so the synchronization to match the digital time and the analog hands.
here are the step by step procedure including visuals, click on the link.
I hope this will resolve your issue.
Thank you for choosing Fixya.
Mar 06, 2011 | Tissot T-Touch T33159851 Wrist Watch
How do i set the time tissot t touch expert
Hi. As it would take a lot of time to write and draw all necessary figures right here, I would like to give you direct page address for all TISSOT TOUCH EXPERT settings. If the print is too small - use ZOOM tool to magnify it. Hope it will help. Follow this link: http://support.tissot.ch/usersmanual/141-en.pdf
Jan 13, 2011 | Tissot T-Touch T33159851 Wrist Watch
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Changing to metric
1. Activate Crystal
2. Tap center until units screen appears (This will say either 12 or 24h and F ft or C
m)
3. Press and hold top + button until watch beeps, display will be flashing.
4. While flashing, press top + button which will change the C m to F ft and back
5. While flashing, press bottom – button which will change the 24h to 12h and back.
This will also change the date format. If in 24h the date will be Date/Month, if in
12h it will be Month/Date.
Oct 03, 2008 | Tissot T-Touch T33759851
Tissot T-Touch T33159851 Wrist Watch Logo
180 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
