Question about Dometic Rooftop RV Air Conditioner
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but have not had this problem. When the furnace shuts off due to temperature being met, my fan continues to blow and does not shut off. Does this sound like there is something wired incorrectly?
    New Friend:
    Problem Solver:
Not wired wrong..if furnace runs through thermostat..make sure fan is in auto position.. fan being on low ,med or high.then fan will run
Posted on Sep 02, 2014
  • Mike Butler
    Mike Butler Sep 06, 2014
    If fan was in run position it should be running all the time, correct?
  • Robert Sep 06, 2014
    mike,if your refering to the ac then yes..furnace will shut down when desired temp is reached
  • Dometic Master
  • 6,674 Answers
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
Posted on Jun 08, 2011
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
I have a springdale travel trailer with a dometic ac system. When I turn the air on, with the fan in the auto position on the thermostst, the compressor turns on and runs, but the fan does not. The...
Neither.
The fan should run in the 'auto' position.
If it runs (on hi and lo settings) then I doubt if anything is wrong with the fan motor.
I would think your thermostat is bad and needs replacing.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
Furnace has a mind of its own
If your thermostat no longer controls your furnace possibly could be the control board in the furnace or a shorted fan relay.
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
239 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
