Kelvinator K600 does not agitate or spin every secons or third wash
4 Suggested Answers
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
Maanita
  • 1142 Answers
SOURCE: My washing machine will ocassionally not spin.
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Posted on Mar 24, 2009
SOURCE: my kelvinator k600 top loading machine fills and
the belt has cutting
Posted on Aug 23, 2011
Does the pulley to the gearbox need to not slip on the shaft? Does the set screw need to be tightened if this is happening?
this may help
http://forum.appliancepartspros.com/washer-repair/533129-washer-spins-fills-drains-wont-agitate.html
Jan 02, 2017 | Washing Machines
My Kelvinator K600 Washing Machine sometimes does not operate on the Spin Cycle
Spin clutch soliniod not engageing underneath (replace).
Oct 02, 2016 | Washing Machines
Can the kelvinator k600 washing machine heat water?
If the rating plate is around 3KW, then it has a heater installed.
Apr 08, 2015 | Washing Machines
My Kelvinator K600 drains as it fills. Possible cause?
Drain hose too low Gravity is pulling out the water as fast as it fills. All washers have this same problem. The hose must be at least 30 inchs above the floor. Sudsing detect possibly?
See page 48
Apr 12, 2011 | Kitchen Ranges
Not spinning or agitating
Most likely you have a bad belt or a defective lid switch.
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
Agatator in wash drum, only the bottom spins the top two thirds does not spin
Paste the link to this video to show agitator repair.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Nov 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
