Question about HP Photosmart C7280 Printer
I inserted non-HP cartridges into my C7280 printer and the display says "the ink cartridges appear to be missing or damaged", If I put the original HP cartridges back in, the error message disappears. Please help
    Scholar:
  • 56 Answers
Turn off your printer
Open the cover
1 .move the cartridge carrrier manually to the center manually with your hands from left to rgiht ( 5x )
2 .Open the cartridge carrier Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean specially the gold plate .CLean also the area where you return your cartridges also the contacts on the cartridge carrier make sure its clean OK .
Then return it again
You may also do that when your printer is on
1 . Open the cover first wait for the carrier to move to the center
2.thats the time you will remove the cartridge and clean and clean the cartridge carrrier
3.open again the cover reinsert the cartridges
make sure its close properly
Hope it help ..
If still nothing happens probably you have a fake cartridge which is not recognized by the Hp printer Ill be advising you to return it back and asked for a replacement OK
Posted on May 28, 2011
I want to disable messages about the inkcartridges.
Sadly not. The HP Photosmart C7280 insists on having a full set of cartridges installed in order to print. It does this because the printheads are actually part of the printer itself and can sustain damage if they pull air into the printhead.
The out of date message is also non-negotiable I am sad to say.
Feb 05, 2013 | HP Photosmart C7280 Laser Printer
I want to use non HP Ink ! but this happened !!!
Send a test print to it from the printer properties. If you did not have any issues before you re-charged the printer cartridge, try another cartridge.
Oct 10, 2012 | HP Photosmart C7280 Laser Printer
How do I stop the message of 'Missing or damaged cartridge
Delete and reinstall a printer driver and then go into the protery of the new driver and search for update go to inksell.com they will give you the latest driver
Jun 03, 2017 | HP Officejet Pro L7680 All-In-One Printer
How do I check my ink levels
Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
Let me know if you have any other questions. Please rate this solution. Thanks.
Mar 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Screen says "the following ink
I am having the SAME problem!! The cyan color for some reason!!! All of these are BRAND new HP ink cartridges!! Have you figured out how to fix this??
Feb 21, 2011 | HP Photosmart D7560 InkJet Printer
HP02 Ink (Expired)
I HP made cars they wouldn't start until you change your dirty motor oil.
May 07, 2010 | HP Photosmart C7280 Printer
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
HP Photosmart C7280 Printer Logo
156 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
