Question about Coleman 9420-700 Grill
Broken valve stem - Coleman 9420-700 Grill
  • 659 Answers
Got this from the Coleman website Click Here you may have to contact them. Also Contact any local camping and RV dealer around you to see if anyone may be able to find a replacement for you as well.
Posted on May 28, 2011
Pressed small stem inside the shrader valve gas pours out when started
Replace the shrader valve the rubber seal on it is broken or cracked. Its not hard to change its like a tire valve stem.
Feb 12, 2014 | 1998 Ford Explorer
Tip
The compression of an engine is low
Few things to check.It may be due to:
loose spark plug
loose cylinder head bolts
blown head gasket
damaged valves/valves seats
insufficient valve tappet clearance
warped cylinder head
bent valve stems
worn cylinder bore
worn piston rings
broken connecting rod
broken piston
on Dec 19, 2009 | Garden
Fouled spark plugs
Usually one of 2 causes. Most common is a bad valve stem oil seal allowing the oil past the valve stem when the engine is shut off.Second is a broken or bad oil ring on that piston. Be blessed.
Jan 02, 2014 | Ford Cars & Trucks
Tire losing air
the best way to find out the leak is to immerge tire in water you will see the leak. don't forget to check the valve without cap
Sep 20, 2013 | 2006 Pontiac Vibe
Backfired then quit
sounds like your exhaust valves aren't opening up which means either your cam is out of round, push rods are bent/flatten rocker arms broken, broken valve stem/seat, hopefully just the valve got stuck closed due to carbon build up
Jun 01, 2013 | 1992 Pontiac Grand Am
Broken valve stem in my cars AC compressor. Wings are broken of the valve stem. No way to screw it out.
This is a job for the AC service mechanic. Once you replace the valve the whole Air conditioner system has to be put under vacuum before re-gassing and you need specialized equipment.
Oct 10, 2012 | Cars & Trucks
The brass valve "stem" that the plastic
Although this grills is no longer available, Coleman may still support it. Try contacting their Customer Support Dept 800-835-3278, if you haven't already. From what the Owner's Manual shows, what you're needing is the entire burner valve assembly. As the brass stem is not a separate part.
I hope this helped and thanks for choosing FixYa.
Aug 04, 2011 | Coleman 9995B750 Grill
I have replaced the o ring that was broken.still leaks
on the outer of the stem there should be a hard plastic washer. Is it there? If not that is the problem. Or you may need to tighten the packing nut. (the farthest nut out on the stem towards the handle).
Nov 08, 2009 | Cascade Faucets Cascade Style Cr1 3x12...
Steamer backed up water pours out under machine
On the cva 610 and 615 the steamer valve gasket tends to wear. Causing the unit to leak. Your best bet it to remove the steamer valve, Looking at the knob stem there is a plastic pin you can press to remove the stem from the valve. Once removed there's a small o-ring on the stem. ( That's where it's leaking from ) replace the o-ring and the stem to be safe. Also take a look at the micro sw to make sure it doen't have any corrosion if so replace it. If not your on the road to recovery. Good luck
Dec 29, 2008 | Miele CVA610
Flooding out
Hello thank you for choosing FixYa.com here are a few things that would cause the black
smoke and stalling.
1 Inspect Piston Ring Set Worn or broken piston rings. grey_line.gif 2 Inspect Valve Stem Seal Cracked or brittle valve stem seals allowing oil to enter combustion chamber. grey_line.gif 3 Inspect Head Gasket - Performance Head gasket leaking coolant into cylinders grey_line.gif 4 Inspect Fuel Injector Rich injector grey_line.gif 5 Inspect PCV Valve Plugged or damaged pcv valve. grey_line.gif 6 Inspect Engine Worn or scored cylinder block grey_line.gif 7 Inspect Piston Worn or damaged piston. grey_line.gif 8 Inspect Valve Guide Worn valve guides
Nov 08, 2008 | 1993 Dodge Shadow
Coleman 9420-700 Grill Logo
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
