Question about Sunbeam Tea Drop Tea Maker HTM5B
How do I order a new pot for the tea drop - Sunbeam Tea Drop Tea Maker HTM5B
  • 659 Answers
Check out Sunbeam's customer support HERE then you can find a local dealer who can order a replacement for you. Sears should be able to order as well.
Posted on May 28, 2011
How do I change the power cord on my Presto Electric Tea pot
Open the tea pot wiring section and remove the old cable and install new cable with same parameters.
Tnk you
Sep 27, 2016 | Kitchen Appliances - Others
Replacement pot
The absolute BEST place I ever found to get anything like that is Ebay. We had an EXPENSIVE coffee pod coffeemaker & my grandma put an electric skillet over the drip tray, thereby warping it to oblivion. I had given up saying anything long before & began just cleaning up after her mishaps. I went to Ebay and was thankful to find another at a really great price because it was used. (The market was filled with new ones & the home page for the maker of this coffeemaker had none in stock; kind of a hint that they got tired of carrying them so they Ebayed them to clearance them out, I think. However they were MUCH more expensive than this used one.) $8 later you can't tell a thing happened. If you can't find what you want the first time keep looking. People post new things every day!
Jan 27, 2014 | Sunbeam Tea Drop Tea Maker HTM5B
How do you use loose tea to make tea in a pot?
You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
If you will use steel pot that is easy to hold and keep.
Feb 27, 2013 | Home
How long should tea brew in a teapot?
When you look in the pot and can see that the tea has brewed to your desired strength, you should take the bags out of the pot or they will keep brewing and make the tea too strong and bitter.
Feb 27, 2013 | Home
Where can I buy a glass tea pot and matching cups?
Glass teapots have become quite popular recently. Here is a link to the English Tea Store, where they sell a glass pot and matching cups.
http://www.yorkshiretea.co.uk/about-tea/yorkshire-tea-how-to-make-a-proper-brew.php
Feb 27, 2013 | Home
How do you clean a metal coffee pot?
To clean your metal coffee pot you can pour boiling water into the pot and add a few drops of liquid dishwasher cleaner. Leave it to sit overnight and in the morning tip it out and rinse it out carefully before you use it.
Feb 25, 2013 | Home
I don't have a manual on how to use the Sunbeam Tea Drop Hot Tea maker, where do I find how to use it ?
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
Sep 22, 2011 | Sunbeam Tea Drop Tea Maker HTM5B
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Need New Tea Drop Part
http://www.householdappliance.com/sunbeam.html
go to this site and order what u need. please mark my answer as a fixya!
Enjoy your tea!! And, as a point of interest, my step son did the same thing and he is an engineer with a MBA..... lol
Feb 27, 2009 | Sunbeam Tea Drop Tea Maker HTM5B
"Tea Drop" manual
It's December, so you may not still be looking, but you put in 1 tea bag in each side for 1/2 pot of tea, or 2 tea bags in each side for a full pot. If you are using loose tea (tastes better - I just buy Lipton), then you put in 1 Tablespoon in each side for a 1/2 pot and 2 Tablespoons in each side for a full pot. Hope this helps!
Jan 21, 2008 | Sunbeam Tea Drop Tea Maker HTM5B
Sunbeam Tea Drop Tea Maker HTM5B Logo
142 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
