Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
Posted on May 28, 2011
Looking for parts list for 1500 poulan/weedeater gas trimmer.
5 Related Answers
Anonymous
  • 246 Answers
  • Posted on May 11, 2009
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Dwain Pippen
  • 377 Answers
  • Posted on May 19, 2009
SOURCE: Looking for the diagram for the gas tank for
You have two lines going into the tank, a small and a large one. The large one goes just inside the tank and connects to the top outlet just under the primer bulb. The smaller line has the fuel filter attached and lays on the bottom of the tank. The other end attaches to the lower outlet on the carb. Hope that explains it for you. Dwain
radsuec
  • 66 Answers
  • Posted on Oct 27, 2009
SOURCE: Poulan TE475Y motor upside down
they were designed that way so the fuel will not spill on a hot engine and cause a fire.
Anonymous
  • Posted on May 06, 2010
SOURCE: Hello I'm fixing my poulan pro ppb200 gas
My service center told me that they are allowed only 2 of these adjuster per year. It has to do with the air quality issue. They don't want back-yard fixer-uppers to pollute the place up. True store - I could not believe it.
The BLUE wire-splice connector, the one that you crimp after you put a wire in each end, is supposed to fit snug around those screws and allow you to adjust them. However I could not get it to work.
If you take a hack saw and cut the lip from around the adjuster screws and then cut a slot in the adjuster screws themselves, you will be able to set those screws with a flat-head screwdriver.
The whole operation takes about 9 pushes of the hacksaw. The lip is aluminum and the set screws are a very soft steel.
Good luck
John
Anonymous
  • 3 Answers
  • Posted on Aug 01, 2010
SOURCE: trimmer starts but the spool wont turn anymore
you're trimmer could have one of two problems, One, if it has a clutch on the engine,( the way you would tell is if it doesn't spin when it idles. it has a clutch) Two, your trimmer would spin all the time, they use round flexable cables stamped square on both ends, which fit into square sockets one at the engine one at the trimmer head, so you're problem is either a worn out clutch, or, the cable is broken, or, one maybe both sockets have become rounded out. I hope this helps you out. Bob
On a featherlite weedeater what's the small green thing that's stuck in the gas cap vent on the inside of cap called???
It is either the tether or the non-return that lets air in, but doesn't let gas out. Most parts are obsolete.
Trimmer parts list - Weedeater Featherlite
http://www.weedeaterfeatherlite.com > parts
Weedeater Parts · 1. Handle · 2. Isolator-Handle · 3. Nut · 4. Screw · 5. Shroud · 6. Shield-Heat · 7. Screw · 8. Screw
Weed Eater Featherlite Type 1 Gas Trimmer Parts
https://www.ereplacementparts.com > weed-eater-feathe...
Need to fix your Featherlite Type 1 Gas Trimmer? Use our part lists, interactive diagrams, accessories and expert repair advice to make your repairs easy.
Featherlite (Type 1) Weed Eater Trimmer - PartSelect
https://www.partselect.com > MFGModelNumber
Get Parts and Repair Help for FEATHERLITE Weed Eater Trimmer - Gas Trimmer. View parts like Engine Fuel Filter and Fuel Line.
1helpful
2answers
Spark plug gap for poulan weedeater
Go to the following site where you may well find parts needed
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
What is gas mixture for weedeater poulan pro 25cc 17" cut
40:1 ratio is the manufature spec for 2 stroke units. unless it is a four stroke then there is no mixture just a good quality gas.
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
How do you fix a broken gas line to gas tank that was previously glued but does not hold and leaks gas to a Poulan GE21 weedeater?
Buy a new gas tank! Are you serious! Or buy a new weed eater, if you can't live without this one, those models are cheap, don't waste your time.
Carburater fuel mixture settings on weedeater gth22 hedge trimmer
your best bet is to buy one small bottle of poulan oil, which will be added to one gallon of gas.
2answers
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
