Question about Durabrand DWT1905 TV
Only getting antenna channels. Snow on all other channels. No choice on menu for CATV/ANT. How does this get changed?
  • Durabrand Master
  • 5,568 Answers
You will probably find your answer in the manual; the unit is built by Funai:
Posted on Aug 16, 2008
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: . The direct link to the manual is . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
How do I change from anntena to cable the menu dose not have a choice to do that
Hello, the original remote has a "tv/catv" button on it and that's how you select whether your on cable or antenna. tks
Nov 08, 2013 | Daewoo DVN-14F6N 13" TV
Does emerson model #20s5b have a switch to convert from cable to satilite?
It's in the channel programming menu. It should say, "Cable/Ant" or "Cable/Air" If you want a roof antenna with local channels, change it to "Air/Ant" Then click auto program with the antenna hooked to it to scan for free local channels.
Jun 16, 2011 | Emerson Televison & Video
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
And here is the manual if you need .
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
I cancelled my dish hooked up a anttena but no signal
Go to main menu and select settings, initial setup, TV signal input, select Antenna, go to channel scan, select digital channel scan if there is a choice, or else channel scan. Wait for the scan to complete, 3 minutes or so. Exit menu, go to input and select ANT.
Wah Lah!
Jul 03, 2009 | LG 42LC2D 42 in. LCD HDTV
In the Setup menu there is an option to specify if you use an antenna or cable. Just switch it to antenna.
Jun 03, 2008 | Emerson EWC1902 19 in. TV/VCR Combo
TV gets all channels, except 2-6
In most cases when you set your menu ("tuner section") to cable, the tv will pick up all channels, but if you set it to "off air" or "antenna" (or whatever the other choice is labeled), then the tv will only go up to about channel 50 or 60. Are you using cable, dish, or an antenna on top of your house. If using cable or dish, then go into the menu on your tv and set the tuner to "cable". I am pretty certain that your tuner is NOT currently set on "cable" and that also there are no local "off air" channels in your area on 2 thru 6, therefore, you see snow on these channels. I have repaired hundreds of tv's and I feel very strongly that your problem is in your menu.
Mar 04, 2008 | RCA F31317 31" TV
You did not say if you were using cable or antenna. If cable, you need to use the remote that came with the TV. Get into the menu and look for channel setup or an equivalent heading. in one of your menu schemes will be a selection fot ant. or cable. Select cable and the other channels will magically apear when you exit the menu option.
Good luck.
Oct 17, 2007 | Philips Magnavox 27MS343S 27" TV
Durabrand DWT1905 TV Logo
107 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
