Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
I have a Whirlpool Refrigerator/top freezer Model ET 21 DK (or DM, whichever one does not have the automatic ice maker). Water is dripping from rear and middle of main-space ceiling onto shelves, and running down under crisper drawers. If I put a container under drip to catch the water, it freezes. I can feel what seems to be ice at the base of the opening. Do I have to move the unit away from the wall to reach anything to solve this problem, or can I do it from the front? I have turned it off to let it defrost. Would a hair dryer help? Thank you for your assistance.
  • gavilan204 May 29, 2011
    Tony, thank you for your quick help. I'm going to try it now. I have ordered the part you suggested. When it comes in, I will probably have to find out where the defrost heater is, and how to reach it.
    Thanks.
    Ilse
    Tony: Thank you. I defrosted, used the hair dryer, cleaned, put everything back. Until the part arrives, I'll see if this helped for the time being. I could see what you pictured when I had everything apart, so I should be able to install the part. I assume I just have to turn it off while I am working, and not have to defrost and warm everything up again. Thanks for your help.
    Ilse
  • 3,018 Answers
  • Whats happening is the drain lines are freezing and then the water that can't drain gets froze in between the floor of the freezer and the ceiling of the fridge. The a little defrosts from time to time and leaks in the fridge. Not to hard of a fix really.
  • You really just need to defrost the drain lines and then us the item I linked you to and the problem should never occur again :)
  • You will need to pull the fridge out a bit to defrost them lines from the lower end as well.
  • The floor of the freezer is the access to the drain and the evaporator panel.
  • Use a hair dryer and work the frozen drain/lines until defrosted. That's all this really is, a froze drain. When it clears up use the item linked below so it never happens again.
  • This clamps on the the defrost heater and prevents ice from forming on the drains and is a heck of a fine piece that works well. http://www.repairclinic.com/PartDetail/Drain-Strap/726493
Regards, Tony
Posted on May 28, 2011
  • 1 more comment
  • Iron
    Iron May 29, 2011
    • No need to find out, I will show you.
    • First here is a picture of where it will go.
    • The floor of the freezer lifts up.
    • Once the floor is removed then remove the back interior wall of the freezer AKA the evaporator cover.
    • Remove the evaporator cover.
    • What this unit does as act as a transfer of heat from the heater to the drain hole to bring the heat a little more closer and more efficient. the top two prongs (in the picture) will connect to the heater and the bottom "probe" (see picture) sits shotgun to the drain hole. This moves the heat closer to the drain hole and it will not freeze anymore.
    • Hope this helps.
    Regards,
    Tony
  • Iron
    Iron May 29, 2011
    • You are welcome. You are correct Lise. And there will be some basic instructions when your part arrives, It will go in 1,2,3 and this problem will be a memory. Also yes, have the refrigerator unplugged when putting the part on. As for it being cooled down you can do this but if you want to avoid having it unplugged to long and the food warming just wear a pair of neoprene gloves or even a pair of dish washing gloves (which are far cheaper and multi use) and just unplug the refrigerate right before replacing the part. This will protect your hands enough for this purpose. It gets warm but it won't melt them gloves. Just don't grab the heater for an extended amount of time. Good luck to you. Come back any time.
    Regards,
    Tony
  • Iron
    Iron May 29, 2011
    Also if it starts freezing again, before the part comes, then flush it with some warm water. When the water flows to the drain pan (behind the kick plate at the bottom of the fridge) freely, you know the line is good and defrosted.
    Regards,
    Tony
Water dripping into refrigerator from freezer
Drain in freezer is clogged usually with ice. Unplug frige and defrost 6 hours with doors open. Pull lower front grill and check drain pan for water. If no water remove rear panel inside freezer to clear drain hole, below coils in the middle...
Mar 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool 21. cu. ft top freezer drips water into the refrigerator.
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Mar 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is dripping down the back of the refrigerator inside and pool in the bottom of the refrigerator. Whirlpool/ freezer on top ET-1CHMXKQ02. Freezer is still working and icemaker is still making ice.
Defrost drain tube is clogged. Have to clear this by removing back wall inside freezer and removing the ice build up inside the defrost tray and tube. Very very hot water and hairdryer will help with this process. hope this helps.
Jan 28, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Water is dripping from the freezer into the refrigerator compartment and pooling up in the various drawers/bins.. The drip pan underneath is completely dry.
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
949 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
