AccelaWriter8200 feed problem
Like the other person, I'm having feed problems with my old workhorse of a printer. Mine isn't lifting the paper out of the tray, though the lift mechanism on the tray seems to be working. I get four marks on the top paper where the rollers above are at least touching, but it doesn't pick it up. Actually this may have been going on a while, with partial feeds one time, then okay the next, etc. Now nothing, even with different brands of paper, and after cleaning (blowing & dusting) out all the bits I can see. If the roller is too smooth, as you mention, what can I do about it?
Thanks.
    President:
  • 2,072 Answers
Most likely you will have to replace the feed rollers. 1-800-828-5881 and follow the prompts.
Posted on Aug 18, 2008
Paper jam error code 13.01.00 hp 3505n printer
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding. A lot of times, it is as simple as the paper backstop has slid back and the roller can't grab the paper that is 2 inches out of reach. Since you've replaced the tray and paper, I would think you might have noticed that. Is the paper moving out of the tray at all?
Jul 04, 2012 | HP COLOR LASERJET CP 3505 N PRINTER
The paper feeder rollers are slipping and the paper is not feeding properly. What can I do to fix this?
This is a good workhorse printer -- I serviced these for many years.
You can try cleaning the paper feed rollers with a rag moistened with a little white spirit. This helps remove the paper dust build-up that glazes the rollers and prevents them from gripping the paper.
Eventually, as the rollers become worn, (or, if they are already too worn) you will have to replace them.
Apr 05, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
How to clean the paper feed for brother mfc 7820 multiple jams
It's difficult to said just by typing, you better get your printer services person to clean it for you.
Mar 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Canon MP470 - Paper starts to feed and twists then jams
i had the same problem, mine went into the printer fine and started to tilt. all i did was check the paper input slot and there was a necklace stuck in it, it was an easy fix after all, just had to pull it out. too bad there are more problems than it is worth tho, right now mine wont feed lol
Nov 11, 2008 | Canon imageCLASS D880 All-In-One Laser...
Paper tray won't feed paper & I get a false paper Jam code
This might work for you - it worked for me. HP paper was feeding crooked. Checked the "Paper Type/Quality" in the printing options window - mine was set to Photo Paper. When I changed it to Plain Paper, the paper fed evenly. Hope this works for you.
Oct 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer thinks its out of paper
  1. Open the Document Feeder by placing your fingers under the opening where you feed paper, and lifting upwards.
  2. Locate the black Paper Sensor (the black plastic switch that hangs down).
  3. Make sure the Paper Sensor is not pressed in. It should move up and down freely.
  4. If the Paper Sensor is stuck in the up position, try to gently pull the Paper Sensor back down.
  5. Turn the power off by pressing the Power Switch to the [ O ] position.
  6. Turn the power back on by pressing the Power Switch to the [ | ] position.
  7. Try to make a copy using the Document Feeder.
  • If the Paper Sensor is broken off or pushed in, you will need service on your WorkCentre.
  • If the Paper Sensor is not broken off or pushed in, the Paper Sensor not the cause of the problem
Oct 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Used to print pharmacy medication administration records. Problem!
This sounds (vaguely) familiar; I maintained these excellent workhorses years ago.
It sounds as if the initial settings have changed or been changed that allow one to set paper length, default font and so forth.
Oddly, I saw the service manual first, here:
http://www.eserviceinfo.com/downloadsm/14445/Oki_ML%20320%20&%20321%20Turbo.html
Jul 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feeder won't follow through
The feeder mechanism has so to speak come undone and the printer needs taking aprt and putting back together with the feeder and the cogs interacting with eachother. Ther is a small metal clip lick tensioner to keep it in contact with the cogs, if the clip has come off it just needs securing back in place.b8ec9a2.jpg
Dec 26, 2007 | Lexmark X73 All-In-One InkJet Printer
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
48 people viewed this question
k24674
jasbo
jasbo
