Question about Samsung HCM4215W 42" Rear Projection Television
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
  • Samsung Master
  • 8,457 Answers
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
Posted on May 28, 2011
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Need to clean lenses and do manual focus/alignment of guns on a VS-5055. How do I get access to them and adjust? Thank you.
the lenses are accessable by removing lower back of unit,clean them with a damp paper towel-wipe them off with a dry one.put back back on unit.
screen/focas controls are in front of unit.remove speaker grill remove black cover using phillips screwdriver.you will see 2 sets of controls.one row is focas.one row is screen controls.red,green,blue.turn each focas control slowly to get the clearest picture for each color.screen controls are touchy(if you turn then too high unit will shut off)if the black and white picture was good i would not adjust screen controls.if it was bad turn blue and green screens down all the way.picture is now red turn green up until it turns yellow then turn blue up until it turns white
Sep 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Double and curved image on blue warm-up screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2008 | Philips 51PP9910 51" Rear Projection HDTV
Pcture problem
Replace both STK392-110 convergence IC's with Toshiba or
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Samsung Hc-p4752e - Double Picture
Dane,
The convergence amps most likely failed. That unit takes two STK392-010 amps and the most likely cause for their failure are one or more of the 3.9 ohm 1/2watt resistors out in front of the Ic's which have opened or changed in value. There are several of them too, Rz142,143,146,147,144,145,123,124,125,126,127 and 128 and do check them all...
Bill
Nov 24, 2007 | Samsung HC-P4752W 47" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Samsung HCM4215W 42" Rear Projection Television Logo
126 people viewed this question
Henry  Thomas
Henry Thomas
