Mitsubishi WS55711 TV. 'm OK with a a soldering iron and have done similar repairs in the past but I'm far from an expert. I had a convergence problem and have installed a new convergence chip and replaced two bad resistors. First time I reconnected the set came on but the convergence screens didn't show the grids. I discovered I missed connecting a wire and tried again. Got the grid but had two problems: 1) I could align all but the top and bottom right corners which remained pretty badly warped and 2) Powering off and on required me to readjust the convergence. I removed the board and discovered some loose solders on the chip, resistors, and pico fuses (I disconnected to test a few). Fixed the solders, replaced the board and this time I'm back to the issue of not being able to see the grid. I don't see any wires obviously disconnected. Any idea what I might have done or which components are responsible for displaying the grid (I don't remember which wire fixed it last time or more accurately the wire I think it was is attached)? Second
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Since you said replaced a chip, I presume it was the one STK-393-110 which is used in some models--most of their sets use two chips------I know these sets very well.
I have a offer for you---if you have Yahoo IM we can chat there and maybe find your problem.
Here the site emails me etc.
SD TECH
Posted on May 28, 2011
  • vpmbrant May 28, 2011
    Don't have IM - any other way I can review your offer?
Westinghouse ld-3235 picture goes in and out connections are good stops after 30 minutes or so,only 5 wks old
I have the same tv and had the same problem.
If picture appears when you slowly hit back of the tv, then the solution is quite easy.
1-There are 2 small lids on the back of the tv, open the one at the top with using a screw driver.
2- there is a connector on the top, make sure that it is connected well.
As far as I understand there is somehow a connection problem or maybe result of oxidation or something.... 5_3_2012_9_06_22_pm.jpg5_3_2012_9_06_40_pm.jpg5_3_2012_9_06_54_pm.jpg
Oct 09, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
What is needed to repair my panasonic tx32pl10 with a colour problem
The minimum requirement to repair your TV are soldering iron, solder wire, soldering paste, desoldering pump, digital multimeter, knowledge of electronics & service manual of the TV. If any smd is to be replaced you need soldering station. A digital storage oscilloscope will be more than good.
sonsunny
Jun 19, 2011 | Panasonic Televison & Video
My mitsubishi 55" has double
Tv have a problems known as a convergence problems,it dead.The tv convergence board must be replacing parts to solved the tv picture convergence problems.U have all the tools like a soldering iron,desoldering pump or a roll desoldering braid and a roll of solders?Can u also do basic soldering works?Yes,to all these answers.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to do the repair ur self.Or the shop,will cost u like $300-350 for parts and labors.
Jan 17, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a nokia 1110 model ,phone is ok but the mic is not working ,what should i do now tell me the solution
If there's no internal problem like circuit or ic issues, your problem will be fixed after replacing the mic. You can get the mic from any mobile repairing shop or from mobile spares shop. There's a specific mic for your model, but if in case, you can't find one for 1110 model, then get a universal mic (small), you'll need a soldering iron with soldering wire and paste. If you now how to use mobile soldering iron, go ahead but if you are not good at it, i would suggest you to get it done from a mobile repairing shop. A small mistake can lead to permanent damage and unrepairable.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Nokia 1110 Cellular Phone
Three colors bleed on screen and shadows reduces to portion of top screen model mitsubishi 60'' 2001 how to fix
** Caution! Hazardous voltages inside. Technical experience required.
This is a convergence problem. You will need repairs done. likely will cost $200-$600 depending on parts, service call, labour, etc. The convergence ICs are not particularly hard to change but you need good solder skills.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Distorted picture that curves up at the bottom of the screen
My 9 years old Mitsubishi WS-55857 had the same problem (distorted pictures) for couple of months and I was about to buy a new plasma TV. But, I found TvRepairKits.com and I decided to give a try before buying a new TV. I received a convergence repair kit in two days with web site info for detailed instructions with many picutres to explain the process. When I had questions and Ed was very prompt to answer my questions thru the e-mail. I never done solding before, but I am moderate handy person. I spent less than $100 and three hours and my TV picutre looks stunning. I went thru advanced convergence process after I repalced the convergence chips and replaced RCA video cable with better quality and my TV picture looks as good as brand new. Thansk ED for your help! From Portland Oregon
Feb 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Tv turns on then turns off
Sounds like you have the very common failure of the high-voltage transformer. It transforms your house voltage into a smaller contrinuity for the system circuits. You can get one at tigerdirect.com but you will need soldering iron & solder, ohmmeter, voltmeter and if you have never done this before, then a service/repair manual would be handy as well.
Dec 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV image is one greenish color image hardly visible.
two big chips on one seprate pc board
sk_ _ _ _ _ _ ? get the number google it
cost about 10.00- 20.00 etch order them
go to raido shack get solder soldering iron
40watts and solder braid (whicket)
remove the solder pull the chips ,one
small screw holds them to the heat sink
replace with ordered parts set up
covergance Done. you just saved 300.00
Jun 30, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Broken cable tv port on Mitsubishi CS-27209
Yes but repair shop charge alot
for this , and it's easy repair .
You can buy some solder , 40 watt soldering iron , Male coax plug from Radio Shack and
resolder two connections and save 100.00
RADIO SHACK HAS THEM
IT ,
Dec 16, 2008 | Mitsubishi CS-27209 27" TV
Mitsubishi WS-48513
I had a similar problem with my 55' WS Mitsu TV. Their are a number of capacitors inside the TV that were blown (top of capacitor had a convex appearance). TV repair man replaced the capacitors. Ran about $300 for the repair (done at my house).
Apr 10, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
