Question about Canon PIXMA MP830 All-In-One InkJet Printer
Cannon mp830 error: "inner cover is
  • 5 more comments
  • conradw368 May 31, 2011
    Again, the cover is closed, vertical. there is no sensor on the US Model. Problem is likely that the computer has switched to the european mode that has the CD print feature. If so, how do you restet the computer to the US mode?
    Conrad L Wilcoxson
  • conradw368 Jun 01, 2011
    Cannon MP830 USA Version
    Error Message: "Inner cover is open ..."
    Cover is actually Closed (in vertical position)
    your solution had already been tried!
    Try again! I have done all of the above.
    previous recommendation have not corrected it
  • conradw368 Jun 02, 2011
    You added nothing new from prior responses. Can the internal computer be reset? How?
    ... CW ...
  • conradw368 Jun 03, 2011
    Yes, Thank You
    Sergeant:
    Champion:
  • 218 Answers
This may be cause by the CD tray
You can find the inner cd tray cover by lowering the door where printed paper exit. Just above the floor and all the way back of the inside of this area is a peice of grey plastic sort of shaped like a fat elongated "U" - this is the inner CD tray cover - that can swivel down to form a mini platform for the CD tray to rest upon as well as act as a guide for the CD tray as it does its job.
There is a rectangular black piece of plastic, about13.1cm by 0.9cm,located at the base of the CD tray inner cover that obscures the opening for a CD tray to be inserted in for printing. Careful removal of this, plus a few other simple steps found at http://pixma.allhyper.com/, will enable your MP830 for CD printing.
I get that message, or a similar one, if I left the CD inner tray cover down and then try to print something using a different source. Exactly why you are experiencing this error if you did not modify for Cd printing means either someone messed with the printer's internal setting or the Cd inner tray cover is at least ajar. Make sure that CD inner tray cover is swiveled up (a vertical position).
If not this, then try the flap in front of the ink tanks'.
Please rate my answer if this has helped, if this hasnt helped, please ask further ideas via comments on here and I will respond
Warm Regards
Andy
Posted on Jun 01, 2011
  • Andrew Hughes
    Andrew Hughes Jun 02, 2011
    I apologise for not getting back to you sooner, I have opnly just been notified of a update being added. I am also in the UK and work during the day and assist on here of a evening.
    Resetting the language requires these instructions to work but, before you get started, it's important to note that you need to read and understand the instructions properly before you even think about doing anything because if you mess up you can really ruin your whole day.
    Think of it like bomb disposal for beginners..
    Right, that aside here's how you do it using the printer control panel:
    1. Make sure the printer is turned off
    2. Hold the red "Cancel/reset" button (top right corner on control panel) down with a finger on your right hand
    3. Press and HOLD DOWN the "Power" button
    4. Let go of the "Cancel/reset" button and then press it twice
    5. Let go of the "Power" button
    6. Wait for the "Copy" button to stop flashing and go solid green
    7. Press the "Cancel/reset" button five times
    8. Press the "Power" button once
    9. Now press the "Cancel/reset" button the number of times required according to your country codes (see "Country Codes" below).. For Europe I did four presses
    10. Press the "Power" button one more time to commit the setting
    11. Press the "Power" button again to turn off the printer
    12. Your printer should now be set properly and you just turn on as normal
    This is an incredibly simplified list but it includes the detail that
    the service manual leaves out which is you need to press the power
    button to set the "setting" you want to be in.
    Country codes
    • 0 times - No change of the destination
    • 1 time - Japan
    • 2 times - Korea
    • 3 times - US
    • 4 times - Europe
    • 5 times - Australia
    • 6 times - Asia
    • 7 times - China
    • 8 times - Taiwan
    This is an abridged version of the instructions provided and doesn't
    include some of the information about which press flashes what light,
    but it should help if you already have a service manual and can't figure
    out how to set the mode after X presses.
  • 1,179 Answers
What you want to do is to check the unit for any paper that may have got stuck in the printer. Use a flashlight. When closing the cover do so gently until contact is made with the chassis, now give it a firm push into closing/lock position.
It is possible that the sensor is either become disconnected or has failed, in which case one would either need to replace the sensor or reconnect it.
My advice to you would be to Claim warranty support if you can. An alternative would be to contact a printer technician to commence the repair.
Try reinstalling the drivers for this printer, download the latest off the Cannon website.
Try and locate the switch, and check it for obstructions or damage.
Take care!
damnor01
  • 5 more comments
  • damnor01
    damnor01 Jun 02, 2011
    Have you reinstalled the drivers? Also what happened before you got this error?
    You are not going to believe this but Canon's solution to the problem is to close the cover and Press the On/Off Switch to reset the unit. I am sure you have done this many times.
    Click here to download the drivers for your printer.
    What Operating system are you using?
    If that till does not work then you could contemplate on updating the Firmware, However a failed attempt will render the Printer useless, firmware updates are usually done by printer technicians.
    Another option is to disconnect both the power and USB Port connections and then press and hold the Power button for 30seconds while the unit is unplugged and off.
    Tell me how it goes!
    damnor01
  • damnor01
    Good News, on further research I have come up with an excellent idea.
    Click here to send an inquiry to Canon regarding your problem, they should be able to tell you exactly what needs to be done. They will either tell you what to do or they may tell you that component X has died and that you need to bring your printer into the service center so that they can install a replacement part. You may from this be able to claim warranty support, in which case the repair may be free.
    I am really determined to help you!
    Take care!
    damnor01
  • damnor01
    Now that you have e-mailed a Canon representitive, the only other way that possibly may fix your problem is to flash the firmware.
    Caution a failed attempt will render your printer useless.
    Click the link above the one to download the drivers, then click on the Firmware button. Now download the top firmare for Windows Operating System or if you are using Mac download the bottom one.
    Lastly double click on the downloaded firmware, your printer should be on at all times. Do not cancel or abort the update.
    Take care!
    damnor01
  • damnor01
    damnor01 Jun 03, 2011
    Check the manual if your printer has the option to clear the NvRAM.
    Take care!
    damnor01
  • damnor01
    How did it go, any joy?
    damnor01
  • damnor01
    damnor01 Jun 04, 2011
    Did you manage to get it working?
    damnor01
  • damnor01
    damnor01 Jun 07, 2011
    Would you please rate this session.
    Thanking you
    damnor01
  • 670 Answers
have you checked the bottom paper feed tray? see if that was left open or make sure that it's tightly in place.
What's the last thing you did on the printer?
did you change cartridges, reloaded paper, etc.?
on the manual if you have it, try going to #5100 about the inner cover then go back to the drawings and it is the flap infront of the ink tanks they are referring to.
Make sure you close that as well ok.
Check everything inside make sure all lids that needs to be closed are seated in their proper place ok.
  • 2,632 Answers
Welcome to Fixya. To fix the LCD error: Inner Cover is Open, Just follow the instruction below.
Issue: ERROR LCD: Inner cover is open
Clossing the inner cover to clear error messages
1. Press the Open Button (1) to open the Paper Output Tray (2)
cannon mp830
error:
2. Raise the Scanning Unit until it stops
3. Close the Innecannon mp830 error: "inner cover is - ezrahite_3.gif> ezrahite_3.gif 4. Now close the Scanning Unit.
Please let me know what happen. Thanks
  • Rofel Lantican
    Rofel Lantican Jun 01, 2011
    That's the solution to fix the issue if still wont work then accordin to canon you need to have it service
  • 2,404 Answers
Sounds like it may have something to do with the cd tray.
There is a rectangular black piece of plastic, about13.1cm by 0.9cm, located at the base of the CD tray inner cover that obscures the opening for a CD tray to be inserted in for printing. Careful removal of this, plus a few other simple steps found at http://pixma.allhyper.com/, will enable your MP830 for CD printing.
If this doesn't work then that means the sensor went bad. If your machine is under warranty get the printer replaced. If its not then you'll need to call Canon to see if the part is available. They would help you troubleshoot the issue was well to confirm.
Posted on May 28, 2011
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
What does it mean when the alarm window says "inner cover is open"?
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
Nov 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Cannon mp830 error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Sep 20, 2009 | Office Equipment & Supplies
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
When attempting to print, I receive an error message which states "Inner conver is open. Close the inner cover and press OK". However, the inner cover is closed...? I have opened and closed...
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Apr 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Canon PIXMA MP830 All-In-One InkJet Printer Logo
596 people viewed this question
old marine
old marine
