Question about Norcent Technologies LM-965WA Monitor
Monitor flickers with lines across screen - Norcent Technologies LM-965WA Monitor
  • 2,404 Answers
Screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
Posted on May 28, 2011
Testimonial: "thank you for answering so quickly"
4 Suggested Answers
  • 51 Answers
SOURCE: flickering horizontal lines across monitor
Do you have the monitor plugged into a power strip. If so unplug it and plug it directly into the wall.
Posted on Feb 02, 2010
SOURCE: Black & White lines across my monitor
1.Make sure all the connections are secure.
2.Try attaching the monitor to a different PC if possible, to determine if its the monitor or video card.
3.Your monitor might just be going bad
Posted on Jan 04, 2009
  • 211 Answers
SOURCE: flickering monitor
problem with the circuit borad of the minitor ... u would have to get a new circuit board
Posted on Jan 11, 2010
What causes flickering lines across screen
Faulty video cable of your monitor
Sep 14, 2014 | Computers & Internet
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
I have a LGR410 laptop the monitor screen flickers and theres a line at the buttom screen..
Well the flickering can be a loose connection which could be correct but unfortunately if you have a line across your screen. Example a red thin line that goes from one side to the other. That's not good. That would mean the LCD itself is bad. Would need to be replaced.
If your laptop is out of warranty, you can find them on Ebay sometimes but they can be expensive. Depends on how old the laptop is and whether it's worth it to you to drop the coin on it and go through the replacement process.
Jan 28, 2011 | Computers & Internet
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Mar 19, 2010 | iiyama Computers & Internet
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
White horizontal line across screen
Upgrade the refresh rate to 100 Hz and downgrade resolution
Jun 23, 2009 | AOC CT720G 17" CRT Monitor
There is lot of disturbance on the screen
Control Panel
Display (or Display Properties)
Settings tab
Advanced
Monitor tab
under Screen refresh rate, change to 70 hertz or higher
Apply, black screen
(Your desktop has been reconfigured. Do you want to keep these settings?) Yes
OK
OK
Nov 03, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Norcent Technologies LM-965WA Monitor Logo
2,252 people viewed this question
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Brandon Murphy
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
