I have a Defy Laundromaid Electro Logic 1100 washing machine and it is now giving me an E9 error. What could be the problem?
  • 17,970 Answers
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
Posted on May 28, 2011
  • redward79 Jun 24, 2011
    do you have any idea what LE error means? My maching just stopped spinning!
  • Patsy Kruger May 20, 2013
    My machine does it sometimes but then the problem is that the lid is not closed
My defy laundromaid 720 does not stop the waterflow once the drum is full, which leads to water running out the bottom of the machine and then gives me an error LE
problem either in the water level control switch or the solenoid valve that shuts off the water
if the water doesn't shut off but it progresses progress to wash while still filling, it will be the water solenoid valve
Oct 08, 2016 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
My Defy Laundromaid Electro Logic 920 is showing and 'EU' error msg. How do I clear this.
disconnect the power cord from outlet box by 45 seconds. Hold the power button in OFF. Connect again and try it.
If this do not resolve the problem, you must call to the company or some tech service for fix it
God bless you
May 28, 2013 | Washing Machines
My defy laundromaid electrologic 1300 suddenly stops spinning and gives a ue error
I had the same problem: E9 error when switching the machine on. This indicates something is wrong with the pressure switch. (or connection to the pressure switch). When you open the top cover at the back of the machine it will be in the right hand corner (when looking from the back of the machine). This is a round device with a clear tube coming in at its bottom and a three wire connecting plug at its side. When unplugging I found one of the pins corroded (green tarnish). After cleaning it off with some steel wool the problem became intermittent - indicating the connection is not too sound. Just bending the pin slightly did the trick causing it to soundly make contact inside the plug. Problem solved!!
Aug 03, 2012 | Washing Machines
I have a defy top loader washing machine model DTL115. When powered it is writing E9 as a fault.
Hope helps.
May 10, 2011 | Washing Machines
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
I have Defy Laundromaid 1300. I was getting an E9 message.
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Sep 21, 2010 | Washing Machines
Washing Machines Logo
693 people viewed this question
Top Washing Machines Experts
