Question about Pioneer FH-P8000BT Car CD/ MP3 Player
Pioneer FH-P8000BT Sirius satilite. Radio sees signal and tells me who is on and channels but I cannot hear signal! All other functions work fine! This happened all of a sudden, was working just fine!
  • 47 Answers
SOURCE: pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
Posted on May 13, 2008
  • 631 Answers
SOURCE: Missing right channel...
The head unit appears to be defective.
Posted on Jun 12, 2008
marinos
  • 114 Answers
SOURCE: Sirius Activations on VR 185 Jensen Radio
The user's manual containing the instructions can be downloaded here
http://www.asaelectronics.com/techpdf/VR185%20Owners%20Manual%2011-6-06.pdf
Thank you.
Posted on Aug 29, 2008
kenw392
  • 2226 Answers
SOURCE: I have a Pioneer FH-P4200MP car radio and need to
Try pacparts.com.
Posted on Mar 01, 2011
SOURCE: Pioneer AVIC 700 sirius satellite radio stopped working, stuck on
My AVIC-F900BT was stuck on one channel and wouldn't change. There was no sound. Radio head detected Satelitte system, but no buttons worked. Found on the internet a solution that worked for me. I disconnnect the battery terminals for 5 minutes and then connected them. When the system rebooted, the Sirius radio worked fine. I'm posting this hopeing it will help someone.
Posted on Apr 22, 2011
Pioneer car stereo manuals
Download the manual from pioneer website they are freely available complete with a trouble shooting guide
Sep 02, 2014 | Pioneer FH-P8000BT Car CD/ MP3 Player
2009 dodge ram , fm,am,cd,all work fine on radio. but when I hit satelite radio it shows channel 184 and there is nothing.
Is there audio on 184? It sounds like it just needs to be activated. Call Sirius with the SID #, and they can send a signal. Sirius' # is 888-539-7474
Jun 04, 2011 | Sirius Satellite Radio Sirius Starbase...
Looking for the manual for Pioneer FH P880 BT
http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/FH-P8000BT?tab=manuals
Apr 01, 2011 | Pioneer FH-P8000BT Car CD/ MP3 Player
Trying to set up satellite radio function on my clarion dxz755mc
there is more than 1 channel you can set to on sirius try setting your fm to 108 and set siriuus to same if you go into yor sirius tuner you can use the up and down arrows to tune in the stations
Dec 30, 2009 | Clarion DXZ755MC CD Player
Same problems here also, had sp-1 for 4 yrs no probs at all! I even have a brand new antenna, needed to be replaced any way, thought that would fix problem (ACQUIRING SIGNAL) No luck ,why does everything...
Go to XM, I did. But first, call Sirius and ask them to 'refresh' your receiver. Leave unit on channel 1 for 30 minutes and see if problem go away. Make sure to turn off and on with pushbutton on unit - not remote, and do not just diesconnect power..
Dec 28, 2009 | Sirius Satellite Radio Sirius Sportster...
Oct 03, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
No channels
turn power of the radio take keys out of the ignition open drivers side door for 30 seconds then reverce the process works good majority of the time
Aug 14, 2006 | Sirius Satellite Radio S50-TK1 Satellite...
Open Questions:
I have had a FH-P8000BT Double Din Head Unit installed in my Toyota Sienna minivan (after market) for 3 years now. I've used it with no problems up until 2 weeks ago. That day I was using the bluetooth connection to the speakerphone with my Blackberry. I was on a call when I received a 2nd call. With this phone, I have to click over to the 2nd call from the phone itself using the talk button, which I did. When I was done with the 2nd call, I should have clicked the talk button again to go back to the first call; however, I accidentally clicked the call end button instead. I was not able to get back to my original call and finally had to disconnect and try to call them back. However, since that time, I have been unable to receive any calls through the speakerphone; use the handset to answer calls while the phone is connected to the unit; make any calls either by using the voice dial feature or by direct dialing from the phone while the phone is connected to the unit. If I have the bluetooth activated on my phone when I get in the car, it will automatically connect to the unit as if there is already a call in progress; however, I am not able to speak to the other party and the call first gets dropped from the phone and then ultimately I have to disconnect the line from the unit. I have tried turning off the bluetooth connection and turning it back on. I have also tried deleting the phone from the unit (without success) and re-pairing the phone with the unit. None of these fixes have worked and I need help.
Feb 28, 2017 | Pioneer FH-P8000BT Car CD/ MP3 Player
Pioneer FH-P8000BT Car CD/ MP3 Player Logo
56 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
