Question about Microsoft Xbox 360 Console
What my problem is that I turn on my xbox360 and it lights up green and put the channel its usually on the TV and then just says no supporting format when I have my wires for the xbox plugged in. And i just recently Had the three red rings please help me solve my problem it will be appreciated.
  • 7 Answers
The red rings can also mean that your xbox is not receiving proper power from the power supply. make sure all the cables are properly plugged in. Turn off the console, unplug everything, then plug it all back in, and then restart your xbox this should fix your problem, or else your xbox is malfunctioning.
Posted on May 29, 2011
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
My son has turned on his x box which seems to show the normal green light but cannot see anything on any of the tv's in the house. This worked yesterday but I put it in the cuboard last night and now it...
check the video cable that hooks to the xbox... it has a switch for normal tv and hd tv.....and also try a different input on the tv... but first check to make the cable is hooked to the tv correctly...red 2 red, yellow 2 yellow , and white 2 white.....if all of that ok then xbox quite...
Feb 04, 2011 | Microsoft Xbox 360 Console
Hi, I've had my xbox 360 elite console for
might want to check the cable, if you are not getting light from the xbox360 most likely you have changed something on the TV. make sure its on the right setting
HDMI device has to be on first in some cases.
make sure the plug is good and well connected.
restart the xbox360 and try again.
try the xbox on another hdmi device to see if it working.
or try the regular mode of the xbox.
May 26, 2010 | Microsoft Xbox 360 Elite Console
When turn it on the light is red spinning around instead of green
Hi
Disconnect all the cables from Xbox 360 and then reconnect it. Try again and see if its still red.
Here is a link, this is an interactive troubleshooting link, click on the questions to narrow down on the issue along with troubleshooting.
http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=frls
However, if it continues, you probably have to send it to support center to get it fixed.
Following link, provides you online support for troubleshooting and shipping this xbox to them and getting it repaired
http://support.xbox.com/support/en/us/xbox360/RepairLanding.aspx?redirectUrl=http://support.xbox.com/support/en/us/xbox360/registerdevice.aspx?step=repair
And for customer support.
Phone numbers
  • Toll free: (800) 4MY-XBOX or (800) 469-9269
  • Direct dial: (425) 635-7180
  • Hearing impaired (TDD device): (866) 740-9269 or (425) 635-7102
Hours of operationPhone assistance is available seven days a week.
  • 9:00 A.M. to 1:00 A.M. Eastern Time
  • 6:00 A.M. to 10:00 P.M. Pacific Time
Further details:
http://support.xbox.com/support/en/us/xbox360/contact.aspx
This solution is absolutely Free, please rate it accordingly. Thanks :)
May 22, 2010 | Microsoft Xbox 360 Console
RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
Green/red pixels on tv while xbox360 is on
its your junkbox getting ready to redring. Thanks Bill. unfortunately ive had the pleasure of watching 3 do this. One today. .
Sep 10, 2009 | Microsoft Xbox 360 Console
What to do if tv screen goes green and blue when i put halo3 in x
for this type of issue,it could be the DISC,AV CABLE or the CONSOLE itself.
TRY THIS:
• try using a diff game disc with the same title.if it worked,buy a new disc
• if using a diff game disc wont work, try using a different AV cable (the cable that connects the console to the TV)
• if still doesnt work.process a repair for the console at service.xbox.com or call xbox support hotline for phone assistance,you can also check further troubleshooting steps at xbox.com
May 16, 2009 | Microsoft Xbox 360 Console
Xbox360 wireless controller not being detected
1. Turn XBOX360 on
2. Press the sync on the XBOX360, green lights swirl
3. Hold the center xbox logo button on the controller, lights swirl
4. Release the xbox logo button on the controller then press the sync on the controller
Good luck
Dec 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
