Where is the battery compartment? Can't figure out how to remove cover.
  • 53 Answers
Is this for the remote? This is usually on the back and you can either press and slide, lift the cover by moving the clip up or by removing one or two screws from the back to remove the cover.
Posted on May 28, 2011
  • micheleslaue May 29, 2011
    No, this is for the wireless headphones.
How do i change my battery
REMOTE CONTROL HANDSET: (sEE Figure 3)
NOTE: PLEASE REMOVE THE PROTECTIVE STICKER FROM
THE REMOTE CONTROL BATTERY BEFORE OPERATION.
This unit includes one lithium battery, CR2025/3V.
Remove battery before discarding the remote.
Battery Replacement
a) Locate the battery compartment on the back of the
remote control handset. Slide the battery cover out
with your thumb.
b) Remove old battery.
c) Place new battery into battery compartment.
d) Slide battery compartment into the remote control
handset.
NOTES:
• Remove the battery from the equipment when it is not
being used for an extended period of time.
• Remove the used battery promptly.
• Do not discard used batteries into household trash
containers. Contact your local government for disposal
or recycling practices in your area.
Jul 01, 2015 | Bionaire BT200RCU Tower Fan
Changing battery motherboard
Gciappa,
Dell Support > Inspiron 1520 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1520/en/sm/index.htm
Click on Coin-Cell Battery in the right hand list.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft static free cloth on the table you're working on. Helps prevent scratching the table, and laptop.
Turn the laptop over, Battery Compartment facing away from you.
3) Remove the Memory Compartment Cover,
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/html/about.htm#wp1175774
(Number 2 - memory module/coin-cell battery compartment )
The RTC Battery is that small plastic 'bag', that has a Red and White wire coming out of it, and ending in a small white plug connector.
(Real Time Clock Battery. Term coined now for CMOS Battery )
Replace battery, close cover, reinstall main battery, and AC adapter.
Regards,
joecoolvette
Nov 04, 2012 | Dell Inspiron 1520 Motherboard
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
Taylor Wireless 1542 remote batteries how to install
Remove the 4 small phillips head screws on the battery cover and it lifts off.
When you replace the cover make sure the gasket (black rubber) is in it's groove.
Jan 14, 2012 | Taylor 1431 Digital Wireless Thermometer
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
Where do the bAtteries go in the Toy Story 3 Evil Dr. Porkchop Spaceship Play Set Mattel? I can't find compartment?
Here's the instruction manual: http://service.mattel.com/instruction_sheets/R2436-0920.pdf
It's difficult to tell without seeing it in-person but it appears to be on the main unit, probably on the bottom. Look for the battery cover which will have a phillips head screw. You'll need a screwdriver to remove it and insert the batteries as specified in the instructions.
May 04, 2011 | Fisher Price Imaginext Disney Pixar Toy...
How do I remove and replace the cmos battery A135 toshiba
If you have idea about it ......but this link can help you ...in this.. check it.....http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
Please rate and vote if you found this one helpful
Thanks
Sanjay Kumar
Apr 25, 2011 | Computers & Internet
How to change baTTERIES SCC100R
The following procedure should be followed for battery removal prior to disposing of the product:
1. Make sure the clipper is unplugged from any outlets so you don't risk an electrical shock.
2. With a flat head screwdriver, gently pry the top cover from the unit. This will expose the internal circuitry compartment.
3. With a Phillips head screwdriver, remove the four screws on the
circuitry compartment top cover.
4. Locate 6 latches around the perimeter of the circuitry compartment and pry each to loosen top cover.
5. Remove cover to expose the batteries and circuitry.
6. Clip the wires connecting the batteries to the circuit board and
remove the batteries.
Nov 26, 2010 | Remington SCC100R
How do you put the aaa battery in the happy hamster
Turn the hampster over so that the battery cover is facing up. Then unscrew the battery cover. It is the screw in the top left corner of the hampster. This is the only screw that you remove from the hampster. Do not remove the screw that is next to the on/off switch! Once you have removed the right screw, pull the battery cover off. Then you need to remove the whole battery compartment from the hampster. Do not be afraid of damaging the toy, because the plastic undercarriage of the toy is held in by velcro. Turn the battery compartment over. The actual compartment where you put the AAA battery is on the opposite side of the hampster undercarriage. You will need to then unscrew the battery flap and insert 1 AAA battery. I hope this helps!
Oct 24, 2010 | Toys
Battery and memory card compartment cover wont stay closed
ours does the same thing, i couldn't figur out a way to keep it ****, so i just taped it.
Jul 25, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
