Question about Kenmore 29042
I have a Kenmore clothes washer model 29042. After a load finished, the door was locked although the light was not on. I reset it to run a final rinse, again, but when it finished the cycle, the door was still locked and the light not own. So in my infinite wisdom, I forced open the door to remove the wet clothes. Now, the lock mechanism remains locked and the door will not close. Do you suggest how I can fix this without scheduling a repair visit? Thanks
  • 3 more comments
  • mbjoh May 29, 2011
    Kevin, close but not that ez... I unplugged the unit, removed the bottom panel, chkd the filter assemby, and was able to get past the boot (no wire, but glue). With boot pealed back, and the screws removed holding the lock mechanism, the wires running to the mechanism are short and the assembly cannot be pulled out far enough (like in the video) to see how to remove the electronic plugs. It appears the panel front of the washer needs to be removed to access the wiring, but cannot figure how to do that...
  • mbjoh May 30, 2011
    What is the easiest way? Like in the video (I cannot access the lock mechanism because the wiring is too short) or removing the front of the washer (do you have instructions for that?) so I can have access to the wiring to remove the mechanism. To note: the dryer companion to this washer is stacked on top. Thanks Kevin.
    I have a Kenmore front load washer 29042. The lock mechanism needs to be replaced. Kevin White sent me instructions to replace the lock. Problem is the electronic wires are not long enough to pull the mechanism out from behind the front panel (as shown in the video Kevin sent). To actually access the wires and remove them from the mechanism, Kevin agrees I need to remove the front panel (the lower panel has been removed) and need those instructions. Can someone else help? (also the 29042, works as a side-by-side or stack with the dryer; in my case, it is a stack). Thank you.
    that forum has no relation to my issue.
  • 4,323 Answers
Hi
If the video has not helped and you have already opened the lower access panel then please post back with its complete model no. so that I can give step by step instructions for your stacked unit.
Daniel
Posted on May 30, 2011
  • 10,319 Answers
I suggest to use this website on your problem
http://applianceguru.com/forum2/15951.html
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
As you know the problem is with the door lock mechanism that is bad and needs replacement however, before replacing take the bottom access panel apart and clean the drain pump filter assembly completely. Affter this if the problem is still there then it is the door lock assembly that needs replacement, you can view this video to decide if you want to replace it yourself or get this done by a repairman:
Please get back to me if you have any other questions.
Kevin
Posted on May 28, 2011
  • Kevin White
    Kevin White May 29, 2011
    I know but thats the easiest way to replace it
  • Kevin White
    Kevin White May 30, 2011
    That is the only way.....and yes this is the easiest way....Another way is to remove the front bottom access panel and then replace the door lock assembly
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Washer just finished a load worked fine, went to start new load and power button doesn't work but light for the door is on. Kenmore front loader mdl 40441900
Make sure clothing is not keeping the door from closing right, and the machine has had enough time to reset between loads.
Nov 26, 2013 | Kenmore Washing Machines
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Hello! My Kenmore washer door will not open. It's completely locked and will not budge no matter what I've tried. I have a load of cloths in there as well. When I turned the power on detergent and cloths...
Unplug the washer for AT LEAST 30 minutes to reset the Central Control Unit (CCU). If the door still remains locked after a CCU reset, you can still open the door by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
NOTE: The "Fdl" and Fdu" fault codes are for older models of your washer, but the principle of accessing and releasing the door latch is still the same.
If your error code still persists, you may have to replace the door latch. Just follow the guidance in the link below:
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Dec 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore model 44142400 door lock
Did you try to unplug the machine and plug it back in? that is how I reset the lock on mine.
Dec 28, 2008 | Kenmore 43142 Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Washer on the blitz
remove bottom panel and ck pump for obstruction especially if water is still in tub
Jul 21, 2008 | Kenmore 43142 Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
