How do I install CNM Core 120GB portable Hard Drive USB2 0 on my laptop?
  • 4,737 Answers
I don't think this model has a specific method to install and I am sure that this is a plug and play device. Plug in the other end of the usb cable to your Portable drive and then connect the other end of the cable to on of your computer's usb port. Do this while your computer is On. Wait for few seconds and you'll see that your computer has detected a new drive and will start installing it automatically. Once the installation is finished, you be notified that it installed and ready to use. Sometimes you'll also get a warning message to restart your computer to make the new hardware work correctly, even if you simply click "No", there won't be problem since it's a plug and play device. Open your My Computer and there you'll see a new Drive eg. Removable Drive. You can access it as you access the other drives/partitions on your computer.
Hope this helps..
Good Luck.
Thanks for using FixYa.
Posted on May 28, 2011
Testimonial: "very helpful and clear"
  • 2 more comments
  • silvana105 May 28, 2011
    Many thanks for your help, when the device is plugged in it say somthing like the hub as reached its capacity, what does it mean?
  • Lebanon Raingam
    Lebanon Raingam May 28, 2011
    Well, it looks like there's another problem with your usb port or usb driver. Are there any other usb devices to your computer except that Hard drive? If so disconnect them and try again. I would also recommend you to reinstall or update your system. Actually it's not recommend to connect more than 4 usb devices at a time to a computer without using any usb hubs. But since you didn't mention any details, I can't make it specific at the moment.
    Please post back with more details if you need further help.
    Good Luck.
  • Lebanon Raingam
    One this I forgot to mention, but only for your information, we can connect a maximum of 127 usb devices to one computer at a time using usb hubs.
    I do have another usb device attached to my computer, will disconnect and tray again. see what happens.
    Thanks
  • 2,404 Answers
The hard drive is plug and play, no software is required. All you have to do is plug the hard drive into a USB slot. If it doesn't work then you know the hard drive is bad and you would have to get another one.
    Many thanks, I think I need to get another one. I couldn't find any info online to download a user manual/troubleshooting guide, can you help?
How to repair the usb port on maxtor one touch 120GB external drive
You cant repair USB its to small to resoldure unless you are PRO, you could take it apart and connect it to a computer or another laptop and pull out the data here is a guide. http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Reusing_the_Maxtor_OneTouch_III_Mini_Edition_Portable_Hard_Drive
Mar 06, 2011 | Maxtor OneTouch III Mini Edition 120GB...
2 usb plugs which goes where??? maxtor 120gb external hardrive pn9nx2dc-500
You have what is call a USB POWER Y ADAPTER: this is designed to provide extra current to your USB HDD drive from a second PC USB port. Plug the end with two USB connectors to your PC/LAPTOP and the single-ended plug to your drive.
Hope it helps! Let me know how you go.
Dec 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
My PC or Laptop will not recognize my maxtor one touch 111 120GB hard drive. it was working fine befor and now i get an error from windows that says: thre was a problem installing your new hardware
It is your driver related issue.
Check your operatign ssytem version is winxp sp2 ?
SP2 is perfact for usb 2.0
Also you can try to uninstall all usb driver and install inf update utility it is comes with motherbord disk.
You can uninstall usb drivers from computer with device manager .
For that go to my computer proeprty then hardware then device manager then uninstall all usb drivers.then restart the computer then check.
Also check your harddriver usb cable is working fine tryt all usb ports of computrer 1 by 1.
Also try in another computer.
Aug 24, 2009 | Maxtor OneTouch III Mini Edition 120GB...
HDD upgrade to extensa 6601 Wlmi.
The BIOS determine the maximum size hard drive that can be installed in the laptop. Put a smaller hard drive in the laptop say 120Gb hard drive, you will lose approx 10% in the formatting process.
Use the 180GB in another laptop or put it into an USB hard drive adapter case and use it as a portable external hard drive.
Jul 18, 2009 | Acer Computers & Internet
Toshiba 120 GB USB 2.0
check if you have another drive which has the same alphabet as your external drive, if so then go to disk management and change the name of the disk.
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
I have just purchased a hp compaq 6710b laptop from a school. it was connected to their network. i want to put a fresh install of windows xp but it keeps saying that it cannot find the hard drive. it has a...
is the hardrive a sata drive? if it is you will need to install sata drivers when you start your installation of xp
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
Aug 12, 2008 | HP Computers & Internet
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
1,430 people viewed this question
David Payne
David Payne
