Question about LG LD65EL Dehumidifier
Full light won't go out and it won't run - LG LD65EL Dehumidifier
  • LG Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
Most likely the sensor assy has failed. See section 6 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520042&diagram_id=28700153#d28700153
Detailed View: ($18.04)
http://www.appliancepartspros.com/part_details.aspx?part_id=4652359
This senses water and humidity levels.
Thanks for choosing FixYa,
Kelly
Posted on May 28, 2011
    President:
  • 2,080 Answers
If your full light is on then check to make sure your collection bucket is not full. Empty as required.
If the bucket is already empty and the full light is still on, then you have a problem with the float level switch. This is a common problem on all models and is usually just the result of an improperly placed bucket interfering with the float mechanism. Take out the bucket and try jiggling the little float assembly with your finger to see if you can loosen or dislodge it. Make sure the unit is set to MAXIMUM so it will turn on right away if you manage to fix it that way. If this works, then try to see if you can tell what was interfering with the float mechanism and correct it.
Good luck.
We just bought the DE45EJ. We removed it from the box and plugged it in....nothing. No lights, no beeps, no hint of life. The power source is good. The room temperature is normal. The bucket isn't full...
If you just purchased and it won't turn ON, don't waste time trying to fix the unit. Return it to the place of purchase for a replacement unit or a refund.
Thanks for choosing FixYa.
Sep 10, 2011 | Haier 45-Pint Dehumidifier
My Kenmore Dehumidifier wont turn on. There is power to it ,all the indicator lights are on, it just wont start. What's wrong?
Check the over fill switch in the tank. If this is stuck it thinks the tank is full and won't come on. After that your compressor may be bad or the starter for the compressor. The Dehumidifier is basically a small air conditioner that condenses moisture in the air then it drains into the tank.
Jul 13, 2011 | Kenmore Dehumidifiers
Our bucket full light is on but we only have a hose running out to the drain. My husband shorted out that circuit but the light still comes on and we can't turn on the unit. Any help with this? Thanks
The reason the light cam of the first time was because the either the attached hose is clogged or the hose connection of the unit is clogged. When this happens, the bucket full light comes ON, because of the clog or the bucket was not reinstalled properly and didn't trip the bucket, safety removal, trigger switch. Be sure the bucket is reinstalled so the the Top and Bottom fit squarely into the bucket holder.
Hopefully, your husband can undo what he's already done, clear the clogs and the unit may run again, as it should.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Haier Dehumidifiers
Bucket full light flashes, humidity setting won't change - only says 01
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 07, 2011 | LG LHD459EL Dehumidifier
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
The bucket full light won't go out and the
Try resetting the bucket, making sure that it is set properly and triggers the safety lever/switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit from the wall outlet and wait 12-15 minutes. Plug the unit back in and turn the Master ON/OFF Switch to ON. If the bucket is installed properly, the unit should revert back to the original factory settings.
Hope this helps solve the problem.
May 28, 2011 | LG Dehumidifiers
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
LG LD65EL Dehumidifier Logo
391 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
