Question about GPX Televison & Video
Remote doesn't work even with new batteries - GPX Televison & Video
  • 53 Answers
Make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
Posted on May 28, 2011
2 Suggested Answers
SOURCE: My HP PL4260N doesn't show
surely there is problems with the lcd controller... you need a qualified technician to check the power consistency in your lcd controller.
Posted on May 27, 2011
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Remote doesn't work
did you program the remote? or was it standard? if you did all of this it sounds like a new remote is in order,but I'd get the codes from the maker and instructions on reprogramming it,if that fails you need a new one
Apr 24, 2013 | Amphion Mediaworks T342 System
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
Nov 13, 2012 | LG 42LC2D 42 in. LCD HDTV
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
94 full size blazer keyless remote doesn't work.
Does the spare remote work? Have you tried to reprogram it? These remotes are very cheaply made and prone to key pad failure. To program the remote click this LINK, if that doesn't work buy anew one on eBay for cheap.
Jun 13, 2012 | Cars & Trucks
My Maestro IR remote no longer works after 10 years
The infrared (IR) LED / remote may have stopped working. Since it emits IR light when used, you won't be able to actually see the light with the ***** eye. This makes it difficult, but not impossible to determine if the LED / remote is working or not. You can see if it works by pointing it a night time security camera - the type that has it's own built in IR LEDs to light up the area and does not need visible light to shine on the area (some video cameras can also "see" this light when playing back video taken of an active IR light source). Either record or have someone watch the display while pressing a button on the remote and aiming at the camera. You should be able to do this in broad daylight it will look like a flashlight shining into the camera.
If the LED in the remote is proved to be functioning, the IR receiver in the switch, or some other internal part of the switch may have failed. Since the receiver doesn't light up - there's no way to determine if this is the case without actually replacing the switch. It doesn't matter really, as there are no user replaceable parts in the switch - it either works, or it doesn't.
Ultimately, the best way to troubleshoot will be by replacing components with known good types. Use a battery that tests "good" on a tester, in a new or known to be good remote, used on a new or known to be good switch. You'd would deal with the situation by swapping only ONE component at a time. Once you change the device that allows to circuit to work, replace the new components with the old - except to last one; as this was likely the component that caused the failure.
Try taking the remote to a Home Depot, Lowe's or other similar store with a display of these switches. Do what you need to do to your remote to see if you can control any of the switches/ lights.
Apr 13, 2012 | Electrical Supplies
Remote control shows a battery/yellow ray. Doesn't work
You may need a new battery. There is an issue with Harmony One remotes where if you leave it on the charger too much, the plastic casing of the battery can expand and cause issues with the remote not getting power. I had this issue happen to my Harmony One, and I called Logitech and they replaced the remote.
Even if that is not the issue, you can buy a new battery to see if that helps. You can get a battery by calling their sales line which is 1-800-231-7717.
Hope that helps.
Jul 20, 2011 | Logitech Harmony One Advanced Universal...
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
I have a kelvinator air-coditioner and the remote doesn't work 6711A20011E is the number on the back as well as N216 can I buy one somewhere I'm from sydney.2210 I have changed battery serveral times and...
I am trying to work out the same thing. The airconditioner doesn't seem to have a part number on it. The only place I have found that sells remote controls is
http://spares.bigwarehouse.com.au/product_info.php?cPath=64867_69567_69609&products_id=1617902
but that seems to be part number 671120011A. I don't know if it would work properly.
I don't even know if a new remote control will fix the problem. But I guess I'll have to try.
Feb 16, 2011 | Heating & Cooling
Televison & Video Logo
348 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
