Question about Craftsman 25cc Gas Line Trimmer
The cord wont pull out at all - Craftsman 25cc Gas Line Trimmer
  • 3,740 Answers
Hi nd erl;come to FixYa. I am Kelly
You most likely have some corrosion on the cylinder walls or crank shaft / rod end bearing.
Remove the spark plug and spray a generous amount of WD 40 into the spark plug hole. Let it sit over night. The next day try pulling the recoil. If that does not work you will have to remove the air shroud, grasp the flywheel NOT by the fins and rock it back and forth until the engine turns freely. After it rotates freely... dump out the WD 40. Allow several minutes with the cylinder head inverted for the WD 40 to drain. Then attempt a start after re-installing the spark plug. If the WD 40 keeps fouling the plug you can very carefully wash the cylinder with gas... just stay away from any sparks or flames and make sure to wipe up / dry off any residual fuel.
Since you did not include a model number this a generic response that should get you going again. If there is a problem with the re-coil... again I need the model number please.
Thanks for choosing FixYa,
Kelly
Posted on May 28, 2011
My pull cord won't release, to start engine.
if you cant pull it possible engine failure or debris in recoiler --check and inspect pull cord --remove plug and try to pull if engine turns it was air locked and should be able to start if locked solid have an internal failure -----if cord wont rewind return spring failure ,,rope jammed or debris
Jul 08, 2017 | Garden
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
Pull cord wont recoil homelite xl 12
You will need to take the cover off to get to the recoil, then remove the pull handle do not let go of the cord! Now ease the cord into the reciol but do not let the cord go, now while holding the cord and the recoil spool rotate the spool 1 revelution clockwise, send the cord back up through the case hole and through the pull handle tie the knot in the cord and replace the case if this still isn't enough repeat the process.Dennis
Oct 31, 2012 | Homelite Garden
Pull cord wont spin the motor
The engagement "dog" is probably rusted in place. Try spraying WD 40 on the recoil mechanism as you pull the starter cord
Jun 27, 2012 | Garden
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
New MacKissic chipper, wont start
it sounds like it is jammed up, take off the plug wire and look inside discharge chute for any debris.
Apr 04, 2009 | Heavy Machinery
Craftsman 25cc Gas Line Trimmer Logo
54 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
