Question about Belkin (F6C800-UNV-PL) UPS System
UPS Can i run a UPS on phone line instead of the battery to have unlimited electricity or if i did put a car battery for more time.
    Brigadier General:
  • 6,966 Answers
Depending on your location, phone line voltages are not suitable to charge the battery nor supply the current requirement of a UPS.
A car battery would work as long as the voltage is identical to the UPS' original battery. It is just the ampere/hour rating that only increased and therefore the usable time likewise increased.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
Benefits of a UPS (Uninterrupted power supply
We all use many devices and equipments that run on electricity. For all these to function properly they need uniform power supply (constant flow of electricity). As the electric supply in many countries is not uniform there is a need for a device to correct it. There are many such devices available in the market today. For example UPS (Uninterrupted power supply), Voltage Stabilizer, Constant Voltage Transformer are such devices available today.<br /> <br /> <b><u>Why buy a UPS?</u></b><br />We can never guarantee that we will get constant power. The power supply always has fluctuations. Surges, Spikes, Brownouts, Blackouts and Noise can damage your electrical appliances especially your computer. To prevent this from happening you need a device that does power conditioning. Electricity has to be uninterrupted. If the voltage is higher than the specified level then it is 'Over Voltage'. If the voltage is lower than the specified level then it is 'Under Voltage'. Both Spike and Surge come under 'Over Voltage' category. But there is a small difference between spike and surge. If there is very high voltage for an instant but comes back to normal immediately then it is called 'Spike'. If there is very high voltage for a slightly longer period then it is called 'Surge'. If the voltage is dangerously reduced to very low within a short period of time then it is called 'Brownout'. When this happens, the computer can be seriously damaged. If the power supply is totally cut then it is called 'Blackout'. Noise can mix with electromagnetic or radio waves or any signals. This is called 'Line Noise'. This may also reduce the voltage level to very low within a short period of time.<br /> <br /> <b><u>How can the UPS provide power when the main electrical supply is cut?<br /></u></b>A UPS has an internal battery. With this battery charger, an Inverter is also present. The inverter converts the 'Direct current' supplied by the battery to 'Alternatinc current' as required by the computer. When there is electrical supply the charger in the UPS charges the internal battery. When there is a power cut, the battery kicks in to supply the DC which is converted to AC by the inverter and power is supplied to computer.<br /> <b></b> <br /> <b><u>What if the battery loses its power?</u></b><br />When there is power cut, the required power is taken from the battery. Therefore the battery keeps losing its capacity. If the power supply comes back before the battery is depleted then the battery charger will start recharging, but if the power supply doesn't come back then the battery keeps supplying until it totally drains out. When the battery drains below a certain level the UPS sounds an alarm for your to shut down your computer and turn off the UPS. Some UPS' even have a built in system that shuts your computer down for you after a certain amount of UPS uptime.<br /> <b></b> <br /> <b><u>How long can the UPS provide power when there is a blackout?</u></b><br />This all depends on the specifications of the UPS and the requirement of the computer. A 600vA UPS for example can supply power to a computer with a 550W power supply for about 10 minutes or more.<br /> <b></b> <br /> <b><u>Tips for buying an UPS</u></b><br />The backup time of your UPS is the most important you need to consider. Other than that, you should know how many KVA (Kilo Volt Ampere) your UPS has. A computer needs atleast 0.5 KVA (500VA) to function. If you are planning to connect more than one computer to a single UPS then you need to get one with a higher KVA.<br /> <b></b> <br /> <b><u>What type of battery does a UPS use?</u></b><br />UPS uses <b>SMF</b> batteries (Sealed Maintenance Free). These type of batteries can be used for 5 to 7 years continuously.
on Mar 05, 2011 | Computers & Internet
Ups says bypass unavailable
This happens a lot. Your input power lines fluctuate a lot from time to time. You get lags and sags and spikes on the power line. The UPS is just telling you this. Nothing you can do about that. Your UPS is operating normally. You don't really want to put the UPS into bypass during one of these fluctuations do you?
Apr 08, 2014 | Powerware Series 9 9170 UPS System
Computer restarts as soon as power goes off, its not an ups . When i manually turn off the power to the UPS, it switches / relay works fine, but if actually if there is a power outage the relay does not...
Your question is slightly confusing. Do you mean that the computer is not powered by a UPS? If the computer is not connected to the UPS, then why have a UPS? If the computer is not connected to the UPS and restarts when you turn the UPS On, your circuit feeding the UPS is overloaded and the voltage dips. If the computer is connected to the UPS, and restarts when there is a power outage, the fault may lie in the reaction of the HP 800. This unit looks to be a line interactive unit and it is not a true on-line UPS. The line interactive and battery backup (no voltage regulation) units both should have a switch to battery power time of 4 msecs, or less. If this unit is faulty and the switchover time is longer, it will not continue to hold up the computer internal power supply. If you are trying to run a laser printer on the HP unit, it won't have enough output capacity.
Feb 20, 2011 | HP Computers & Internet
Ups only puts out 80 volts when power disconnects
These type of UPS's put out a simulated sine wave on battery power. When you test these with a regular voltmeter, it tries to read it as a pure "rounded" sinewave and will nearly always report 80 volts, instead of 120 volts. If you test it with a true RMS voltmeter you'll see that it is 120. Otherwise, these units are getting older and the batteries need to be replaced every 3-4 years. Here's a link to a replacement battery:
Sep 22, 2009 | CyberPower Office Power 585AVR...
Tony166, according to the web, the Panasonic DBS 576 single cabinet phone system will run at a peak wattage of 360 or 3.3 amps. 3.3 amps x 120V = 396 VA.
Also, this is a very sensitive device and needs good clean power to eliminate frequency variations and line noise. You should put this system on an On Line or Double Conversion UPS. Not a Line Interactive or an Off Line unit! Those are the 3 UPS industry standard technologies. The Off Line technology is simply a battery in a box. It can break down a clean sinewave input and feed your connected load a stepwave signal. The Line Interactive unit will provide a sinewave while on battery power, but not during normal operation. Only a true On Line UPS will provide pure sinewave power 100% of the time!
I would suggest at least a 1kVA or 1.5kVA Liebert GXT2 product!
Contact for a quote!
Mar 12, 2009 | Panasonic DBS Battery Backup Unit...
I use my ups to run a fan, a lite, and my computer while I shut it down. An ups is only as good as it's battery. The larger the ups and it's battery, the more watts you can use. The battery will determine how many watthours you get. Some people will put a car battery to an ups. The ups may overcharge the battery and dry it out. The battery may be too much for the ups charging circuit and burn it out, dead ups. I put a 12 volt computer fan on my ups to keep it from overheating, another problem that comes up when you overuse an ups. Where I am, you have to deal with a power company that is not reliable, so I go the extra mile to get more comfort when the power is out.
Aug 30, 2008 | Computers & Internet
Not working
Some UPS have "Battery backup" and "Surge only" outlets. I don't know if it is the case for your model. The "Surge only" outlets are not connected to the battery and will go off during a power outage. Make sure that the equipement that need to keep running during the outage are connected to the "Battery backup".
Important: Never connect a laser printer to the "Battery backup" outlets because to power draw is just too high.
Have you made sure that the battery is connected inside the UPS? (If the battery is user-replacable)
You may do a simple experiment. Connect you UPS you a wall outlet and plug a conventionnal lamp to a battery backup outlet. Then, unplug the UPS from the wall. If the light goes off, then you may have a problem with your UPS.
Apr 19, 2008 | Belkin Home Office 350VA (f6h350-usb-dl)...
Utility LED flashing green/red
Seems like your Battery is very low. Try charging the battery for a few hours. If the problem persists, it maybe the time to get a new battery.
Like all batteries, UPS Batteries (that store electricity and let s you use it in case of a power failure) have a limited life. This life is averaged to be around 2 years. So in case your UPS has been in use for approximately that much amount of time, the battery is in a near death situation.
For instructions regarding replacing the battery, please refer to your UPS Manual.
PS: Also, I have noticed this kind of behavior when the UPS is connected to a socket powered by an Inverter. This kind of behavior is observed when the Inverter battery is running low.
Oct 12, 2007 | Compaq UPS T1500 XR (204155-B32) UPS...
Belkin (F6C800-UNV-PL) UPS System Logo
89 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
