Question about Poulan 14" Chainsaw
What is the proper spark plug gap - Poulan 14" Chainsaw
  • 252 Answers
Hi there grumpoldvet
proper gap is 0.024 to 0.028 thou
NGK plug type bpmr4a or Champion cj7y
cheers pauly46
Posted on May 28, 2011
  • 608 Answers
Hi, .8 mm or 30 thou, hope this helps, regards Phil.
What is the spark plug gap for Briggs 20.5 hp
For a proper answer more info is needed. Here's a Briggs site that has spark plug gaps listed. Gap is not hyper critical for running.
.030-.045 will work. The only time I've seen gap matter was when it was too close like .005, the engine wouldn't run.
What is the right spark plug and gap for my small engine Briggs Stratton
Sep 21, 2017 | HP Garden
Spark plug gap 96 gov safari ACDelco platinum 41-942
Spark Plug Gap - AutoZone
www.autozone.com/.../specificationsMain.jsp?...Spark+Plug+G...
AutoZone2004 Mercury Grand Marquis 4.6L SFI 8cyl ' Specifications ' Spark Plug Gap.
AstroSafari.com • Spark plug gap size?
www.astrosafari.com/viewtopic.php?f=43&t=81409
Jul 27, 2015 - You're doing a '96? I think EARLIER 2nd Gen 4.3's used a .045" gap ; I believe it changed in 2000 or 2001 but don't quote me on that. All i'm ...Missing: gov
AstroSafariVans.com • View topic - spark plug gap question
astrosafarivans.org > ... > ENGINES GENERAL/PERFORMANCE
Nov 28, 2012 - 15 posts - ‎4 authors
My question is do I gap the spark plugs per 89 4.3 specs or do I use the 95 .... The vortec heads for a V8 chevy are 1996 and up however there ...Missing: gov
What is the proper sparkplug gap? - CarGurus
www.cargurus.com > Questions > GMC > Jimmy
CarGurusMar 16, 2013 - My Haynes manual and various places I've seen online say the gap is .045 inches ... spark plug gap for 1992 4.3 160 HP? ... Used GMC Safari".Missing: gov
[PDF]2000 GMC Safari Owners Manual - GM Extended Warranty
www.vadengmpp.com/owners-manual/gmc/2000-GMC-Safari.pdf
Jan 27, 2016 | Cars & Trucks
What is the proper spark plug gap on 04 Chevy malibu ? Is it .060 ? Is that not to big ?
If you have the 3.5 liter engine, that is the correct gap. If you have the 2.2 liter engine the proper gap is .042. Hope this helps...
Nov 10, 2012 | Cars & Trucks
2006 FXSTD Spark plug gap?
Hi Anonymous, HD 6R12 spark plugs are gapped at .040"
Good luck
Apr 16, 2012 | 2006 Harley Davidson FXSTDI Softail Deuce
Did tune up on my 91 ford f150 302 5.0L V8 4x4 pick up which included s[ark plugs and wires, cap and rotor, oil change, new oil and air filters...now it is riding rougher and worse gas mileage than before?...
did you properly "gap" the spark plugs? many spark plugs have to have the ends properly "gapped" before installation, by using a "gapping" tool/wheel to properly space the arc gap to the correct distance.
if the plugs were properly gapped, or already came pre-gapped out of the box for your specific vehicle, then you may have air getting into the cylinders around the spark plugs. were you careful to properly tighten the spark plugs straightly into place, or is there a chance that you left one loose, or, even worse, cross-threaded one of the spark plugs?
Mar 26, 2011 | 1991 Ford F150
Misfiring after replacement of spark plugs and wires
If it wasn't misfiring before. Make sure you have the proper gap on the spark plugs. Make sure you have the wires connected in the correct order. If you have the old wires, you may want to end up trying those one at a time to make sure you don't have a defect wire either.
Thank you,
Lee
Mar 04, 2011 | 1994 Ford Escort
No spark at plug hear cylinoid click but no spark at plug.350 yamaha warrior 1997
Just checking if your battery is fully charged, your coil is properly connected and ignition cables are properly seated and if you are still using carburator, the float are seating properly as not to flood the combustion chamber. The spark plugs are clean and properly gapped. I have found that if sprk plugs are not properly gapped at recommended gap, it may not give out sparks to burn compressed fuel.
Cheers. If you find this advise helpful, please give it a rating. Thanks
Dec 24, 2010 | Yamaha RD 350 Motorcycles
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
What is the proper spark plug gap for a 1970 Buick 350 4bbl.
1970 Buick LeSabre 5.7L 350CID V8 GAS CARB - GAP=0.030
Apr 12, 2010 | Buick LeSabre Cars & Trucks
Poulan 14" Chainsaw Logo
102 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
