Question about Sharp CD-BA200 CD Shelf System
Protect is displayed on the unit. I know it is a speaker wire. Do I unplug all speaker wires and then plug in one at a time and turn unit on and repeat till I find the bad wire??? Please advise. System is Sharp cd BA-200
    Brigadier General:
  • 8,546 Answers
Why are you asking instead of doing?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 29, 2011
I have sony radio model no STK-KM22 it display flashing protector messege and I cant play any thing ,how I can solve thi ploblem?
Unplug for 30 seconds unplug speaker cords.twist all wire ends together tightly for each set of wires.one little wire not twisted tightly with the rest can short out throwing receiver into surgery protection mode.plug receiver back in or reconnect it.test each wire set to see if external speaker wire issue.wire sets are twisted good you will know as each speaker will come back on.twistem tight soldier them or use liquid tape to keep connection working properly.use surge protector to protect unit receiver.
Apr 09, 2017 | Sony Audio Players & Recorders
Tip
Display says Protect , and the unit does not start.
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
on May 27, 2009 | Sony STR-DE597 Receiver
Trying to hook up sony s-master with componet cables an the s-master displays on the display ''PROTECT UNPLUG'' however with nothing plugged in the s-master, works fine
Check speaker wires, any wire seems shorted and causing Protect Unplug error message in receiver.
Good way to sort out bad wire is plug one speaker at a time, turn On receiver check, turn Off, then plug next speaker wire until you find out what speaker wire activates protection circuit of receiver.
Thanks.
Jan 01, 2011 | Audio Players & Recorders
Sony str-de835 in protector mode
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jun 04, 2010 | Sony STR-DE835 Receiver
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
"protect" on the screen
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 18, 2009 | Samsung 650W 5.1-Channel Home Theater...
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Bad speaker wiring.
Internal fault.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
Protect
Bad speaker wiring.
Internal fault.
Regards.
Oct 26, 2008 | Samsung HT-Z310T Theater System
My DVD HT-Q9
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
Sep 23, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
SONY STR-DE675 RECEIVER
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
Sharp CD-BA200 CD Shelf System Logo
85 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
