Question about Grilling
Need a manul on how to use the rotisserie and the infrared burners on a Better Homes and Garden Grill modle # GSF2818KL.
    Brigadier General:
  • 4,736 Answers
I must admit, I was thrown by the Better Homes & Gardens Gas Grill. I have been in the grill business for 15 years and that was one I had never heard of. However, the model number looked vaguely familiar. So, with a little research, I discovered that the grill is manufactured by BBQ Tek Enterprises Inc of Canada. They make a lot of look-a-like grills (the model you have strongly resembles a Weber Genesis). In any event it was only sold by Better Homes & Gardens on their website as a Bond Majestic Gas Grill. Ace Hardware, now has the exclusive on it in the USA. I tell you all this, so if you have a warranty issue, BBQ Tek Enterprises is who you will have to contact 1.877.885.8227.
Below is a link to your Owners Manual, that you ca download and print for future reference.
http://www.bbqtek.com/us/manuals/GSF2818K.pdf
Hope this helped you and Happy Grilling!!
Posted on May 28, 2011
How do I light the rotisserie infrared burner?
Nice unit. I was looking at it last night in Home Depot.
http://www.weber.com/grills/series/summit/summit-s-470
Should spark ignite like the burners surely? Perhaps the igniter post needs adjusting, or a lead has become disconnected?
Aug 12, 2015 | Weber Summit S-470 Liquid Propane Grill -...
Glass turns black inside
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Apr 29, 2013 | Napoleon Fireplaces Napoleon Prestige PRO...
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
Rotisserie infra red value would come on,it comes on when I hold it in...
I'm assuming, that after you release the burner knob, the infrared burner goes out. You need to hold the knob in until the infrared burner gets glowing hot. If it doesn't remain lit after doing that, the thermocouple that keeps the burner lit, either needs cleaning due to a grease build up or replacing the thermocouple entirely. To clean it, alcohol and a cotton ball works well.
Hope this helps you troubleshoot and solve the problem.
Apr 25, 2011 | Lynx L30FR-1 Gas Grill
Fire goes out and gas continues
What you described is not unusual with the main burners of a gas grill. As, there is no thermocouple on each burner, that would shut the gas off to that burner. You must turn the burner off, yourself. To the best of my knowledge, there is only one American made grill that has a thermocouple on each burner and it isn't a Weber grill.
If it's the infrared rotisserie burner, you're talking about, then that's a problem. That burner does have a thermocouple that may need cleaning or replacing.
Hope this helps to solve the problem.
Apr 15, 2011 | Weber Grilling
Flame does not stay on Rotisserie Burner grill but jumps back into the throat where the air mixes with the propane gas. What's wrong and how do I fix it?
If it's windy outside when this happens, the wind is blowing the infrared burner out. Especially if the hood of the grill is open. The Rotisserie should only be used with the hood closed.
Feb 09, 2011 | Grilling
Infrared rotisserie burner mounted on back will not stay lit.
I have the same problem - What I determined is first the gas safety valve button would not push in. I researched the problem and found that if you ever overheat your grill by "cleaning it" by placing foil over the grill, then the intense heat likely overheated the valve. ( in my case) which I replaced. After replacing the valve, my rotisserie would not stay on. I found that the thermocouple was defective. the TC is a piece of copper that attaches to the back of the safety valve and the other end has a probe that is up at the rotisserie burner. When you light the rotisserie, and press in the valve button, it should stay lite after about 10 seconds.
When the probe heats up, it sends and electrical signal to the electro magnet which operates and keeps the valve open. I bought my thermocouple from PEX supply for $9.50. DCS wants $56.00 for the same part which is manufactured by Robertshaw. Part number you want is 1980-072 thermocouple .
Dec 07, 2010 | DCS BGA48-BQAR (NG) All-in-One Grill /...
Grilling Logo
229 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
