Question about Maytag Dishwashers
Maytag dishwasher model mdbtt59awb, when you turn it on dosen't do anything, after few minutes all the lights go out.
SOURCE: Maytag Dishwasher model # MDB5130AWW
I had a similar issue with my MDB5130AWW. The Wash was interupted and wouldn't come back on. Not knowing where to start I read some other solutions on this site and started by opening the bottom cover. Thats where I found a 4 page diagnostic / Electrical Schematic. Start with the Sales Demo mode of pressing the Rinse button 5 times within 5 seconds. I had to do it twice before the washer came "alive". I was estatic after reading about the $100 mainboard cost and maybe more for other parts. The document has other test and what different keypads mean when flashing. Thankfully I didn't have to go that far.
Posted on Aug 27, 2008
aborcass
  • 2651 Answers
SOURCE: My Maytag Jetclean Dishwasher Model #
possibly a bad door switch losing contact, only after opening nad closing is it making contact again. part number for door swtiches and holder 99002254 retails for a about $25
Posted on Nov 05, 2008
  • 17 Answers
SOURCE: Maytag MDBTT59AWB
sounds like a bad timer/ control board.
Posted on Nov 11, 2009
Daniel S
  • 4323 Answers
SOURCE: Dishwasher model MDBTT59AWB- washer fills
Hi
The issue is either with the motor that is not running or the door switch-latch assembly that has gone bad and should be replaced. If you are sure that the switch-latch assembly is working fine then the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 16, 2011
Daniel S
  • 4323 Answers
SOURCE: Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 19, 2011
After a few minutes into cyle delay lights start flashing
Light(s) Flashing/Blinking - Door Opened - Delay ... - Maytag
www.maytag.com/...light(s)-flashing-blinking...delay.../PH7053/
MaytagQuestion: Built-In Dishwasher - Light(s) Flashing/Blinking - Door Opened - DelayWash - Cycle Power. Answer. Product Symptom: Built-In Dishwasher - Light(s) ...
Sep 26, 2015 | Bush Dishwashers
My maytag W10199645 dishwasher won't start
Maytag model w10199645 was starting intermittently, and sometimes only when we pressed and held the start button for 10-15 seconds. Finally tonight it just wouldn't start, period. I unplugged it for 15 minutes, then used the Heated Dry/Normal/Heated Dry/Normal and it started back up on its own.
Mar 23, 2012 | Maytag Dishwashers
Lights blink but nothing works
Hi, disconnect the power supply for few minutes, say 5 minutes and then turn it ON. Check, if that helps. If not kindly revert with more details :-
1. Which light is flashing?
2. Is there any message like ' CL ' or anything you could see?
3. How old the machine is?
4. Is there any sequence in blinks like 7 blinks then pause and then 7 blinks?
Let me know,so that i could provide you with more accurate diagnosis.
Jun 21, 2011 | Frigidaire FDB520RH Builtin Dishwasher
Abnormal Dishwasher Clicking noise
Try spinning each of the spray arms in turn and in both directions to see if the noise is related to an arm or it's bearing. You might have to disassemble the lower spray arm mechanism to the deck to inspect the recirculating pump impeller for anything that might have gotten pulled into the impeller. That pretty well covers anything that rotates in the machine except for the motor itself. Hope this helps!
Mar 13, 2010 | Maytag MDB3100 Dishwasher
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
My Maytag Jetclean Dishwasher Model # MDB4010AWB Serial # 16163916uk is stoping midcycle, it doesnt make any noise or anything just stops. Water left sitting in bottom and have to open door then close...
Nov 05, 2008 | Maytag Dishwashers
Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Oct 05, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Dishwashers Logo
71 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
