Question about Thetford Norcold RV Cooler/Freezer
Have a Norcold 3-way fridge for RV. Model 8663 - have taken it out and laid on left side for 1 hour - plugged into electric and fridge still does not get cold - it starts to get cold and after awhile it turns warm, even heats water in the glass in freezer we had to test it. Any suggestions as to what the problem is?
  • Thetford Master
  • 6,674 Answers
Not sure who said lay it on it's side, but it should be turned upside down for 24 hrs, then back upright for 24hrs, then restart and see what you get.
Posted on Jun 05, 2011
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Sep 27, 2009 | Thetford Norcold RV Cooler/Freezer
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
Rv fridge not working on electric
the element can be broken or the thermostat
Aug 11, 2009 | Refrigerators
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
487 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
