My zenith big screen 1994 model is blurry and super red from what ive heard i need fluid replacement in the 3 tubes, can i replace fluid myself or is that a tach's job.
  • 125 Answers
You need new picture tubes, they are expensive, big screen tv life is about 10 years
Posted on Aug 16, 2008
Picture shows blurry
You will have to determine which of the picture tubes has contaminated fluid. To do this, you have to pull the screen off and see which tube is blurry. You will find a red, green and blue tubes when the set is on. To learn how to remove and replace the fluid, please check the following web site. www.TVRepairKits.com. Be sure you have the model number and know the symptoms you describe to repair this. Thanks for asking and show all hands of support!
Mar 29, 2011 | Philips Magnavox 9P6034C 60" Rear...
My screen is discolored and blurry. Please advise..
Sounds like contaminated fluid. Each of the 3 crt's in your set have coolant to keep them cool. This coolant over time gets contaminated and causes extreme blurry picture. ITs extremely common on the Magnavoxs. Its also a pretty big job. Replacing the fluid isnt too difficult but because the tubes have to be removed it means both physical alignment and electronic alignment will be necessary. Also dont remove the green tube until you have done both the blue and red and aligned them to the green. Then do the green.. I hated doing that job lol.. I dont recommend you trying it and probably wouldnt be cost effective to pay a shop to do it either.. I recommend buying a new set... Sorry
Oct 19, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
The screen seems dark and blurry
take off the front panel carefully, usually 2 screws around the controls. Next, stick your head in and look at the red green and blue tubes. see if they are dirty? if, not look further into the tube using aflaslight and see if there is a white pasty looking substance inside. IF so, you need to clean as you have bacteria growing in the cooling fluid. A big job and you need the gaskets, can order from Mitsubishi tech support..good luck be careful.
Mar 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a 60 inch Phillips 60P8342 and the picure is blurry.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 14, 2009 | Philips 60P8342 60" Rear Projection...
There is a picture but it is blurry with a big yellow blur.
  • Screen looks 3D
Dec 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture on big screen
Chances are, if it's an older set, componants have changed value through use over time, which also includes the picture tubes and associated driver circuits. The way to compensate for this color drift is through adjustments. Either turn the red down a little, or turn the blue and/or green UP. Be carefull though as there are potentially dangerous voltages in and around the circuit boards and picture tubes.
Jun 29, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Zenith TV is Going Blurry
A Zenith model # would be helpful and mo/yr built on sticker on back.Problem sounds like bad pix tube.
Dec 02, 2006 | Akai CF2791 27" TV
Picture is blurry
it sounds like the focus block or flyback is bad.sometimes you can put nail polish on the adjustments controls to make it stay.usually they are marked from the factory with white marks check and see if they are aligned.but be sure somebody with tech-skills help you.the flyback usually has a screen & focus control.(the big red wire to the tubes or block)
Oct 06, 2006 | Zenith Z46Z83D 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
