Question about Poulan Garden
Trying to put poulan 2900 chainsaw back together after someone else took apart how do you put throttle assembly back together?
5 Suggested Answers
  • 14 Answers
SOURCE: Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Posted on Nov 19, 2008
slohry
  • 87 Answers
SOURCE: Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Posted on Apr 09, 2009
  • 37 Answers
SOURCE: Poulan chainsaw gas line routing?
There ARE two holes in the tank. One samll and another larger. One is on the left side and the other is on the right. Look carefully and you'll find them. As far as connections of the fuel lines:
The line from the fuel filter in the tank goes directly through the small hole in the tank to the top nipple on the carb thus giving the carb a constant supply of fuel when running. The primer bulb is used only for "priming" and does not play a part in the fuel flow after that function. The bottom nipple on then carb then goes back to the nipple on the primer bulb which is clearly marked "Carb". The above connections are made with the smaller diameter tubing. From the primer bulb, marked "Tank", the larger diameter tubing is routed to the large hole in the tank. The tubing goes into the tank only 1/2 to 3/4 inch. As far as getting the tubing through the holes in the tank, cutting the tubing at a slant. But no matter what you do it is still a witch. Be patient, use some Vaseline and avoid the temptation to get out the drill and **** the hole to a larger size.
Posted on Sep 22, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a poulan Pro 295 Chainsaw, I took apart the carb.
It appears to be an isolator or buffer #34, but I do not think it would have anything to do with not starting.
Posted on Nov 12, 2009
Where where do I get a exploded diagram of my Poulan Pro blower model ppb 430 vs. also assembly. in diagram that would show me how to put it back together
Here is a source for the exploded views. Enter your model number as "PPB430VS" and chose your type number. This type number is the last of the serial number after the dash.
Poulan Parts Lookup by Model
Apr 07, 2015 | Poulan Garden
Saw is idling to high will not adjust down. What do I do.
Open the carburetor area cover and remove the air cleaner so that you can observe the throttle arm and the idle speed screw which stops throttle movement to set idle speed. If the throttle arm doesn't come back completely to the screw, then likely, the throttle trigger is jammed with sawdust/dirt that prevents the throttle arm from returning. Disassemble the trigger assembly making notes of part placement as you go. You will usually find a plug of sawdust in the trigger mechanism. Recheck the throttle arm motion after putting the trigger back together. You may have to advance the idle speed screw several turns CW to be able to keep the engine running when the throttle works correctly. Idle speed should be set so that the engine continues to run, but the chain doesn't try to turn. Hope this helps!
Jan 04, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a model pp4218avx.when i try and start it.it leaks a little gas out the exaust muffler and wont start
I had this problem and I have no idea how it got fixed, because I carefully took everything apart and put it back together. WOW-it lives and doesn't leak. The only thing I regularly do is inspect gaskets and turn them over when possible. I also am very careful to tighten opposing bolt patterns and evenly when there's only two or three.
Jun 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Clutch brake assembly
I went to Poulan.com and looked at an IPL for a PP4620???, can you say worthless boys and girls? I provide it in case you need parts.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
This thread is dedicated to your saw. Join, post your need and someone wil snap a photo and post or PM it to you.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/showthread.php?t=115309&highlight=poulan+4620
HTH Lou
Feb 22, 2010 | Poulan Pro Chain Saw 46cc 20"
Moby bladez pull cord spring out how do i assemble it
The only trick to getting this back together is patience and determination. You must keep the spring flat as you wind it tight.
Jim
Jun 09, 2009 | Poulan 12a Elec Blower/Vacuum
Throttle assembly
try www.jackssmallengines.com parts look up poulan 2500 they have exploded views of all parts this may help you will probably have to search arond abit
hope this helps
Nov 01, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
103 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
