Question about Dishwashers
Thick black oily globules left on plastic containers.
Machine works fine but has started leaving thick black oily globules on plastic containers , crockery doesn't seem to be affected .
  • taras mum Aug 18, 2008
    I will try this and let you know how I get on. I do keep my dishwasher very clean though including the filter. Thank you for you advise.
  • andrew parry Aug 25, 2008
    Oily black specs in filter area and one some plastics..
    Sears has no idea.
  • 706 Answers
Try cycling it in energy efficient mode with the heater off.. seems like you are melting something since it only happens to plastic containers.. Also, check and clean anything that remains in your drain filter...Hope that helps...
Posted on Aug 17, 2008
SOURCE:
What is an antonym for globules?? droplets
Hi, both of these words are nouns and often as not a lot of nouns do not have a direct opposite (antonym), however if you don't mind a bit of "artistic license" my suggestions would be:
Globules - by definition these are tiny balls of something (such as a thick liquid) Suggest Icebergs.
Droplets - by definition these are very small drops of liquid. Suggest Oceans.
Trust this helps, regards Alan.
Feb 06, 2015 | Google Computers & Internet
Engin produces thick black oily discharge at exhaust
Check fuel pump diaphragm or stuck needle and seat
Jan 16, 2014 | Boating
Lexmark E120. When it prints it leaves a thick black smudge about 1/2-1 inch thick down the entire left side of the paper in waves. Is there away to clean something or replace something to correct this?
It's time to take your printer to a professional technician, to trouble-shoot and fix this problem,
if you don't know how to do this by yourself.
Jul 30, 2011 | Lexmark E120n Laser Printer
Car is running hot and the heater quit working. i have a thick oily substance in my radiator resservoir. this car is a 1999 Saturn sl. in the radiator reservoir it has a brownish thick liquid and when the...
Sounds like a head gasket, the oily substance is actually oil. Do not drive the vehicle, at some point a $1000 repair will into $3000 repair when the engine seizes.
Nov 19, 2010 | 1999 Saturn SL
MY AL-1641CS LEAVES A THICK LINE ON THE PAPER. I
If the drum is rotated in the proper direction, it should be clean. If the line on your copy is in about the same location from to back as the line on the drum then your only option is going to be to replace the drum unit. The drum unit contains a drum cleaning blade that is supposed to clean the drum as it is being rotated. This is apparently not working in your case. These cleaner blades can be replaced if you have someone locally that can do it. The cost of a cleaner blade is about $20.
Good Luck and Thank You for using Fixya.
Jul 09, 2010 | Sharp AL-1641CS Laser Digital Copier
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Xt cranks replacement. The black plastic
Have a look on this website under the bottom bracket articles:http://www.parktool.com/repair/byregion.asp?catid=61&imageField2.x=19&imageField2.y=8
Nov 02, 2009 | Cycling
Machine stops sewing when I hit a thickness
it may be that your motor belt needs tighening or the belt may be damaged - you can check belt and adjust tension yourself once side cover is removed.
if you are sewing thick seams and the needle is resting on the seam as you begin to sew you may have to help the machine to get started. if the fabric is not thick it must be belt tension.
scott.
Jun 17, 2009 | PfaFF Hobby 4260
Oily coolant 2
Hi myxj87 -
It is possible that you have motor oil leaking into your cooling system. A common cause of this condition is a bad head gasket. Since both coolant and oil flow through the cylinder head (through their respective passages), a bad head gasket would allow for cross-contamination. Does the car still run well? Have you noticed any coolant in the oil whilst doing oil changes?
Mar 24, 2009 | 1997 Plymouth Breeze
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
