Question about Century Welding Tools
I have a century mod 11705093 wire welder. I have replaced the trigger switch. Even before this though, when you pull the trigger without wire in it the feed motor spins freely, when you put wire into it and pull the trigger, the feed motor is not spinning and the wire heats up and burns out where it enters the cable. Any solutions?
    Sergeant:
  • 281 Answers
That sounds like a direct short short to me. My mig has 1 nylon guide tube,one in front of the feed wheel and one just before it inters the liner.They are both insulating the drive wheel from the wire.If the teeth marks are deep enough they will act like a saw and cut right through the nylon tubes and short out on something.You may need a new liner ,the liner is carrying the current instead of the wire.That may be problem. Thank You for choosing FixYa.com
I have a century mod 11705093 wire welder. I have - liner.jpg In addition to guiding the wire, the back end of the liner, shown here, contains o-rings and seals to ensure the shielding gas doesn't escape the gun cable.
Posted on May 28, 2011
How can i identify the positive leads on a wfw12179welder by matco?
Use a voltmeter between leads. Most cheapie wire feed welders like this don't switch power to the torch, they just switch the gas feed and drive motor when you pull the trigger. So even though the trigger is not active, the electrode has voltage applied.
Jan 21, 2018 | Motorcycles
Phase three on cv or cc have current going to mig wire, wire is live without hitten gun trigger. mega arc is hooked up to a Hobart suitcase
May need to take gun apart and see if trigger is sticking or replace lead.
we use Miller at work. The feeder has a switch that makes the trigger turn off and on with quick pull of trigger so you don't have to hold it entire time.
check wiring to make sure it's wired right so your not bypassing the trigger switch.
hope it helps.
Nov 02, 2015 | Hobart Welding Tools
Weld corp mig 100 turn machine on and wire keeps feeding without touching trigger even disconnected trigger switch and keeps feeding
sounds like a shorted transistor. follow the wire of feedmotor to the electronics board. and the follow it to the power transistor that controls it.( probably it is screwed to a cooling plate) replace it ( it can be 2 in some cases)
Sep 28, 2014 | Welding Tools
MIG welder 250 feeding wire at erratic speeds
Gun trigger contacts or switch circuit is closing somewhere (shorting). Unplug connector and jump the two terminals if it works and will weld disconnect jumper if problem persists it is not in the gun or cable hose. Keep chasing it far as possible without taking bolts or screws out of machine unless you know what that stuff inside will do to you, pretty sure the problem is not in there anyway.
Apr 02, 2012 | Miller Welding Tools
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
Miller 350p welder gives a "help 3" code.
Code help-3 Indicates that the gun trigger was pulled and held during power up. Release gun trigger and clear fault condition. Also, this display can Indicate no open circuit voltage detected when gun trigger is pulled and no arc detected within 3 seconds, this means that the trigger was held without any metal contact. The machine will shut down in order to avoit the wire to continue to run freely.
To fix:
Turn on the machine without pressing the trigger on the gun. Then increase to the max the wire speed. Then turn off the machine. Press the trigger after the machine was turn off, then without releasing the trigger, turn on the machine and release the trigger after 2 seconds. That will take care of it.
Nov 17, 2010 | Miller Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
MIG wire is always hot without pulling trigger
Check your manual, there are a lot of mig units on the market that are alway "Live" alternatively, the relay has either shorted or you have wirering problem on the switch.
Jan 07, 2009 | Welding Tools
Welding Tools Logo
330 people viewed this question
Top Century Welding Tools Experts
Bill Boyd
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
