Question about Skil 7 - 1/4" Electric Circular Saw No.5176
Loaned a Skil 5150 to a friend and when he returned it, the saw seems to run slow and the brushes produce lots of spark.
    Sergeant:
  • 281 Answers
You will need to change the brushes for sure.Easy job at least.There are two types of brushes,The ones that can be fixed without taking the saw apart.The other brushes once you open the case and look at the front of the brush holders you will see some small holes.Take out the old brushes and push the new brush past the holes and push a piece of wire through the holes.Make sure the wire is long enough to go through a vent so you can pull it out when every thing on the body is buttoned up.
I use a piece of cardboard or Styrofoam to keep track of the bolts by just poking them in as I take them out,a magnet is good for the small stuff.
Posted on May 29, 2011
How to replace brushes
I could not find instructions or video on your model, but on your model the brushes are under the plastic cover opposite from the blade.
if the cover is removed you should be able to see how to replace them.
Jan 19, 2015 | Skilsaw 5150 Circular Saws
How do I install new brushes on 15 amp motor for 3400 skil table saw?
http://www.ereplacementparts.com/skil-3400-f01234000a-table-saw-parts-c-130_164_7498.html
Here is the breakdown - I believe the brush tubes just friction fit with the wire connected by a spade terminal.
Jan 14, 2015 | Skil Saws
How to replace the guard spring on skilsaw 5150
trial and error and lots of patience with tweezers or small needle nnose pliers
Aug 14, 2014 | Skilsaw 5150
Skil saw stops I bump it it starts then it stops I bump it it starts
The two groves could be caused by the auto stop pin in the brushes but I would also check the brushes are not getting stuck in the brush holders.
Dec 11, 2012 | Skil DWOS 7.5 AMP RECIPROCATING SAW VS...
Where can i get a manual?
just call or email skil they will email you the manual
If you're looking for an older model that isn't listed, call 1-877-SKIL-999 (1-877-754-5999) or email Customer Service.
Sep 11, 2012 | Skilsaw 5150 Circular Saws
Skil saw 5155 owners manuel
I found something on amazon, take a look here: Skil Circular Saw Model 5125 5150 5155K 5170 5190KC Owner Instruction... . I hope this was helpful. Cheers
Jun 05, 2012 | Skil Saws
Skill Wormdrive HD77 saw sparks are coming off the brushes
you have a problem with worn brushes or the armature might be failing. UNPLUG the tool and remove the brushes to check their condition length and look at the face of the brush for any unusual wear. Then look into the brush tubes themselves and slowly rotate the armature for discoloration/raised commutator bars.
Jun 23, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
I have a skill 3400. I flipped the on/off button and the motor started and then stopped immediately I figured it was the switch as this happend before but I put in a brand new switch and it still won't...
There is no fuse in the Skil 3400 saw. Check your cord, then brushes. You might have a broken brush spring, causing one brush to hang up in brush tube. Possibly there maybe a lot of sawdust holding a brush up.
Feb 09, 2010 | Skil 10" Table Saw 3400
Skil 7 - 1/4" Electric Circular Saw No.5176 Logo
282 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
