Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
How can i manually ignite the grill - Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
  • 8,220 Answers
What I do is remove the grates and flame guards and light the burners with a stick lighter then turn em on low and cover them with the flame guards then sit the grates back on there.
Posted on May 28, 2011
How can I stop the oven igniter continuing to spark after the oven has lit
This should not be a problem as the setup is it doesn't know which gas knob has been turned on, therefore the oven and grill spark to ignite either .
Hope this is helpful
Regards
John
PS if I had known the make and model number you can probably get a manual online.
Oct 31, 2014 | Ovens
The ignition swithc is not attached to anything and so grille will not light
Reattach the wire(s) from the spark igniters on the burners to ignition module.You will have one extra wire and that is the ground wire, that should be attached to the grill's frame.
Get me the correct model number and I can forward you the Owner's Manual for your grill.
Hope this helped you and thanks for choosing FixYa.
Sep 09, 2011 | Char-Broil CharBroil Master Flame Gas...
The igniter box inside the grill is rusting and disintegrating. I bought the Weber igniter kit at Home Depot, but it has a red push-button, and I can't see how to begin replacing the igniter under ...
I have provided 2 links for you. One is the Assembly Manual for the Genesis B 330
and the other is the Owners Manual. Both should prove invaluable to you, in replacing the Ignitor Button. You can download and print each manual for future reference.
Assembly Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/AssemblyInstructions/Genesis_310320330_LPng_AssemblyInstrctns_56507_022811.pdf
Owner's Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/OwnersGuides/Genesis_320330_LP_OwnersGuide_56508_111010.pdf
Hope this is some help to you. Please let me know. Thanks & Happy Grilling!!
Jun 17, 2011 | Weber Genesis Silver B Grill
In June I bought a new Weber grill but the auto ignitor does not work--there is no click--therefore no spark. I can light the grill manually.
If there is no click, it is most likely the igniter module is bad. The igniter module should be available at any Home Depot or Lowe's; in any case, your owner's manual will show you how to remove and replace the igniter module. If you don't have the owner's manual, I will include a link to one online; you will need Adobe to open it. Here is the link: http://www.bbq.us.com/images_templ/weber-manual-3741001.pdf
Try this and if it doesn't fix your problem, come back and let me know and we will troubleshoot further. Good luck!
Nov 16, 2009 | Weber Spirit? E-310 Propane Grill
My silver c igniter does not work..need to manually light..burners work..is new igniter worth pruchase? grill is almost 6 years old
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Jul 18, 2009 | Weber Genesis Silver C Grill
Igniter Stopped working
Igniter could be shot. Take out igniter and put near something metal. Push button to see if sparks occur. If not igniter is no good. If this works, the end of wire that is near wear the igniter sparks to light grill could be to far away from metal, bend to get closer to metal, so it will spark, or end could be covered with grease, clean end and try for spark again.
Jun 14, 2009 | Weber Performer Grill
Second burner will not ignite on Weber grill
Its probably an obstruction in the burner. Take both the burners off and clean them inside and out with a brass brush. You need to clean them both, since the second burner is dependent on the first working properly.
Step by step procedures are in your manual. Go to http://weber.com/help/manuals.aspx to download it.
Jun 03, 2009 | Weber 1851001 Gas Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
128 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
