Question about Phil & Teds E3 Twin Seat Jogger
Need new replacement huud - Phil & Teds E3 Twin Seat Jogger
  • 419 Answers
If you visit this link, you will be able to purchase the part.
http://shop.philandteds.com/parts/e3-v1/e3-v1-v2-sunhood-phil-and-teds
Hope this helps.
Posted on May 30, 2011
Needs new battery and will not adjust to new time
If it needs a new battery, replace it! With a new battery this clock should set it's own time. If it doesn't, there is a problem with the circuit and the clock will either need to be replaced or repaired.
Feb 17, 2014 | La Crosse Radio Controlled Atomic Clock
Fuel pump needs to be replaces on 2000 Chevrolet suburban, do I also need a new filter, relay and induction?
Do you know for sure that the fuel pump failed or do you have a bad relay? If the fuel pump relay is good no you don't need to replace it. The fuel pump unit comes with the sending unit and a sock filter. I would replace the inline fuel filter when you replace the pump. In line fuel filters need to be replaced every 36000 miles. If that filter starts to plug up it makes the pump work harder which leads to premature failure.
Jan 17, 2011 | 2000 Chevrolet Suburban
Need to replace broken front spring. would like to do it without having to compress spring. can this be done?
YOU NEED SPRING COMPRESSOR.OR REPLACE THE WHOLE NEW FRONT STRUT WITH A NEW COIL SPRING ALREADY IN STRUT DONT NEED TOOLS IF WHOLE UNIT NEW.
Oct 30, 2010 | 2001 Pontiac Aztek
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
I need to replace the brake rotors and pads on the front of my 2008 Dodge Magnum SE. Is there anything special I need to know. Haven't replaced brakes on this new of a car before. Thank You
You'll need the Allen or Torz wrench that fits the locking bolts on the caliper so you can remove the calipers and you will need a caliper compressor to compress the caliper cylinders to install the new brake pads once you replace the rotors. I would have the Rotors checked to verify they need to be replaced before replacing them. It is possible you can save money by simply having them turned instead. $25 for each rotor is better than the normal $150 to $250 to get new ones.
Sep 30, 2010 | 2008 Dodge Magnum
Hp printer model A909a indicated new ink cartridge needed. When I installed new cartridge kept giving message needed new cartridge. When I removed new cartridge ink was leaking on outside edge of...
Follow the instructions below to replace the printheads in the All-in-One product.
Video of replacing the printhead
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
Aug 28, 2010 | HP Office Equipment & Supplies
I need to replace my
No just go to your dealers and perchace a new stick guide replacing it.You will see when you have the new one how easy it is to change
Nov 16, 2009 | 2001 Volkswagen Beetle
Need to replace sound card for Sony vgn-t350p
It's true that with a laptop, replacing some parts means replacing the motherboard as they are integrated parts, this applies with the sound card. If your laptop is under warranty then you should be able to get it fixed, otherwise you need to weight the cost of replacing the motherboard verses buying a new computer. Seeing as how the motherboard in a laptop is pretty much half the computer, it may be cheaper to buy a new one.
Mar 12, 2009 | Sony VGN-T350/L PC Notebook
Need replacement cord for rival CF153-WM
check out aelectric dryer or stove for cord or a replacement
Jul 15, 2008 | Kitchen Appliances - Others
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Phil & Teds E3 Twin Seat Jogger Logo
93 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Dorel UK
Dorel UK
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
