Question about Giant MTX 260 DS
I want to raise the handlebars and the seat for this bike, I purchased it second hand
    Brigadier General:
  • 8,546 Answers
Http://www.giant-bicycles.com/en-US/page/135/
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Posted on May 29, 2011
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
Are there road bikes that allow a more upright position? I have neck pain when my neck is extended.
Have you tried lowering the seat and raising the handlebar?
Have you considered a recumbent bike?
You can also try a cruiser style bike.
Jul 05, 2014 | Cycling
How do you lift a 1982 yamaha 920 virago to the center stand
Left hand on handlebar grip, right hand on handle under the seat, right foot on the centerstand lever, bike vertical on flat ground with the handlebars/front tire straight. Push down on the foot lever of the stand while lifting from the handle. Most of the work done is by pushing the lever and the lift handle is mostly for stabilizing and helping to raise the bike. This applies to all bikes and once you get the feel for it you'll find that any size bike is pretty easy to put on the stand. I can center stand my CBR1100XX while on the bike, first time was hard, but once I got it down it's fairly easy.
Apr 05, 2014 | 2000 Yamaha XJ 900 S Diversion
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
How do I raise the handle bars on a Diamondback Sorrento? Purchased new in June. 16" frame, 26" wheels.
Web search teh question "How do I raise the handlebars".
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Aug 07, 2011 | Diamondback Cycling
I have a Forza model mens bike. I ride with the seat fully raised. However I have to bend down too much to reach the handlebars. My question is is it possible to raise the yoke in the front forks in order...
You may have a bike that is too small for you. If you are unable to return it the stem can be replaced by one that raises the bars more or that does not go forward as far, or the bars can be raised by using what is called a "stem riser". It is best to refer to a bike shop for info on purchasing the correct stem/riser or installing such an item, but below is an example of one stem riser and install videos.. Origin8 Tra Lift Stem Riser 75mm Black 1 1 8 stem riser Google Search
Nov 04, 2017 | Lamborghini Cycling
What size should I get?
A bike is the right size when your child can:
•Sit on the saddle and rest the balls of both feet on the ground.
•Straddle the top bar with a comfortable clearance and with both feet flat on the ground.
•Reach the handlebars with a slight bend in the arms when sitting on the seat. If there are handbrakes, your child should be able to grasp them and apply enough pressure to stop the bike.
•ByK bikes have more knee room than other bikes, which helps to lengthen the life of the bike and make the bike handle in a more predictable way.
As your child grows, you can raise the seat post and handlebar stem according to the owners manual limits.
Dec 16, 2010 | Cycling
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Giant MTX 260 DS Logo
222 people viewed this question
Top Giant Cycling Experts
Andrew Taylor
Andrew Taylor
dante
 Russ Hill
Russ Hill
Are you a Giant Cycling Expert? Answer questions, earn points and help others
