Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
Says rear cover the paper is jammerd clear the paper and press ok I cannot locate anypaper
  • 543 Answers
It is stopped work, you can go to service.
Posted on May 28, 2011
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. (Banksy100@hotmail.com)
Feb 11, 2011 | Office Equipment & Supplies
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam clear jam and then press ok
Use the following steps to print a self-test report. Load plain, white paper into the input tray.
Press Setup on the product control panel.
Press 2 to select the Print Report menu.
Press 6 , and then press OK to print a self-test report
Solution one: Clear the paper jam
Step one: Remove any loose paper
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the USB cable from the rear of the product.
  3. Disconnect the power cord from the rear of the product
There are too many steps so please follow up from
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125&tmp_track_link=ot_search
Dec 01, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a new Pixma printer. I got some paper jammed in the printer. After I removed the paper and pressed OK, I still get the error message "Rear cover The paper is jammed. Clear the paper and press...
Make sure all the paper bits are taken off , now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 29, 2010 | Canon Office Equipment & Supplies
Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Sep 22, 2009 | HP Deskjet D2360 InkJet Printer
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
Hp6210 says "Paper Jam. Clear Jam and then Press OK". There is no paper stuck in it, nothing visible at all.
Open the rear clean out cover and check for a jam. Or the rear clean out cover could just be off like mine was. I was get out of paper message. So I found a the HP help manual that there was a rear clean out. I reached around back and found that i twas off, I popped it back on and it works just fine now.
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
261 people viewed this question
old marine
old marine
