When going through the "Internet
  • 984 Answers
Let's see if I can help you. The following is the procedure I use in my business when I encounter the problem you've presented. It works for me 95% of the time.
Begin by turning on your computer and your router
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online
All the best
Ben
Posted on May 28, 2011
    Sergeant:
  • 247 Answers
What info are you pulling from cmd? if its your individual ip thats were your going wrong. if your at home then im pretty sure your using a DHCP protocol if so the dhcp or auto ip box should be checked. your router should have a default ip address that is automatically assigned by the manufacture. If setting up a DHCP connection you have no need for info in your computer. If you are working with static ips then of course those ip should have been provided to you by your isp... Alternatively you can skip the disk set up and log into your router and finish the setup manually wich is very easy. if you need help with manual set up please reply back with your router model and i will be glad to walk you thru it.
Tip
How to configure router. How to access router configuration
When you buy a router they usually come with "setup" Cd's that set up your router, or guide you through the process. What most people do not know is you do not need this CD and in my experience these disc can cause frustration and confusion. <br /><br />You can access your router and configure it simply by using your internet browser like Internet Explorer or FireFox.<br /><br />On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is 192.168.1.1 but depends on your router. <br /> There are a couple of ways to find out this IP address. <br /> -Reference your router manual<br />or<br /> -In <a href="/../support/r9359087-find_wep_key_router_router_security#"><span>Microsoft</span><span> </span><span>Windows</span></a>, go to Start &gt; Run and in the run box type "cmd" or "command". A black window should open(MS-DOS). In this window, type "ipconfig /all". Look near the top of the output that is shows and you should see a "gateway address" field. This number is the ip address of your router. <br /><br />Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the <a href="/../support/r9359087-find_wep_key_router_router_security#"><span>URL</span></a>(address) bar, type the gateway address and hit enter(see image below). A log in box should now show.<span> Again, reference your router manual if you do not know the administrative password</span>. Enter in your password and username. The following website has a list of default username and passwords and you may be able to find your router in the list. Click <a href="http://www.anameless.com/blog/default-passwords.html">here </a>for the website. <br /><br /><img src="g33k4u_7.png" /><br /><br /><br />Once you log in you now have access to the router settings and you can configure what you please. You can configure wireless settings, router log in credentials and other options. Have a look around and get familiar with it.<br /><br /><span style="font-style: italic;"><span style="font-weight: bold;">I would recommend</span> that if your router has a default password for </span><span style="font-style: italic;">admin/configuration</span><span style="font-style: italic;"> access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone(as seen by the link I provided above!). People who set up home networks tend to leave this as is and it is a security risk. </span><br /><br /><br /><span>TIPS</span><br />-If you can't connect to the router and you know the gateway address, try plugging the <a href="/../support/r9359087-find_wep_key_router_router_security#"><span>computer</span></a> into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.<br /> -Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly. <br /><br />-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. <span style="font-style: italic;">Please reference router user manual for more information.</span><br /><br />I hope this article was informative. Be sure to check out my other tips and tricks. You can view my profile by clicking <a href="http://www.fixya.com/users/g33k4u">here</a>, and if you click Tips near the top left, you can view my tips!<br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /><span style="font-weight: bold;">How to configure router, how to access router, how to log in to router, how to configure router security, how to access router configuration, router configuration, set up router, how to set up router, setting up router, router settings</span>
on Jun 10, 2011 | Computers & Internet
Tip
How to Get a copy of the data you've put on Facebook.
<span>To begin this process, go to your <a href="https://www.facebook.com/editaccount.php">Account Settings</a> page, then click the "learn more" link beside "Download Your Information." From there, click the "Download" button.</span>
on Jan 28, 2011 | Computers & Internet
Every time I run the DSL-504 ADSL2 Ethernet Router CD disc to setup my internet connection, always get the dslultility.exe message say "modam not deteched....." but everything is...
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Nov 06, 2010 | D-Link Computers & Internet
How do i set up my web cam without the cd?
Go to "driver download"------- how to find drivers ------ Camera downloads, --- find the Drivers for your Web Cam. Is that easy
Jun 08, 2010 | Computers & Internet
Tip
HOW TO CHANGE ROUTER SETTINGS
Open INTERNET EXPLORER and. (<i>In the URL address field</i>), enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number<br />Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to <b>routerpasswords.com</b> and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.<br />You should now be able to see your <b>wireless </b>router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.<br /><br /><br />
on Jan 23, 2011 | Computers & Internet
Tip
The Best Way to Connect Your PS3 To the Internet/Wifi
<span>Instructions</span> <ol> <li> <p>Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.<br /></li> <li> <p>Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu.<br /></li> <li> <p>Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.<br /></li> <li> <p>Select "Easy" on the next screen that asks what type of installation you want to use.<br /></li> <li> <p>Select "Wireless" when it asks you what type of Internet connection you have.<br /></li> <li> <p>Select "Scan" on the next screen.The system will search for all available Internet connections in the area.<br /></li> <li> <p>Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.<br /></li> <li> <p>Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen. <br /></li></ol>
on Jan 05, 2011 | Sony Playstation 3 (PS3) Console
I'm setting up a new router. I was instructed to go to routerlogin to work withy settings, but I am directed to a web page, not the router. How do I complete setup of the router?
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
7. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
8. Click Apply.
9. Logout of the router.
10. Open up another browser window and try to access internet.
regards,
prakash
Mar 16, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
I dont know crouter configuration
Hai,
Look at your computer's IP configuration. Go to Network and Dial-up Connections, RIGHT CLICK on your network and pick PROPERTIES. Click on the Internet TCP/IP protocol, then click on the PROPERTIES button. Make sure that your settings are OBTAIN IP ADDRESS AUTOMATICALLY.
Then get into your status screen and look at the GATEWAY address. Is that 192.168.0.1 ?
(If you are using Windows 95/98/ME, then go to RUN and go to WINIPCFG)
You can also use the COMMAND PROMPT and type IPCONFIG and it will show the Gateway address. If the Gateway address is slightly different, then try to get into it at that address.
Also from the COMMAND PROMPT, (or MS-DOS window) you can use the PING command. Just type PING 192.168.0.1. If your router responds, you might be OK.
Look at the lights on your ethernet card. Is it GREEN, or does it show YELLOW.
Try rebooting your computer and using PING again.
Then the problem presist it's possible that this Router is NO GOOD.
Hope this Helped!
Aug 27, 2009 | Computers & Internet
Tip
How to set up ps3 to wireless internet.
<span> <li> <p>Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.Select "Easy" on the next screen that asks what type of installation you want to use.Select "Wireless" when it asks you what type of Internet connection you have.Select "Scan" on the next screen.The system will search for all available Internet connections in the area.Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen.<br /></li><span><br /><br /></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
David Payne
David Payne
