Question about Pentair Superflo 1 12 Hp Swimming Pool Pump 340039
I have debris clogging the impeller. How do I clear it?
  • jugarcia626 May 29, 2011
    Thanks. Your instructins clear and helpful. The clog is cleared. JRG
    Yes. The instructions very helpful and the clog is now cleared. JRG
  • 2,404 Answers
Its going to be a challenging job but courtesy of Ehow I found how you can get the debris out of the impeller so it works properly again:
http://www.ehow.com/how_7248487_clean-pool-pump-impeller.html
Posted on May 28, 2011
How to clean debris from impeller? Pump is not drawing water from the skimmer/pool .... I'm hoping the impeller is clogged and not something more serious like a shot motor.
There are normally 4 to 6 bolts around the outside connecting the wet end from the dry end. Undo those bolts and the front of pump should come away. Then you should be able to see impeller. Using a piece of wire poke it through each slot of the impeller to clear the blockage. Then put back together again. Remember to prime the pump
Jan 30, 2017 | Pool & Spa
How can I get to the impeller to see if it's clogged?
Depending what type of pump you have you can use your finger with the system off and see if you can loosen the clog, if not then you have to take the motor off of the pump to access the impeller, if that is the case you may want to call a professional.
Dec 31, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pool pump is a Hayward pressure is at 10 lbs It
Low PSI is usually the result of air in the system or debris in the impeller. (even a clogged pump basket). If you are sure all else is good, open the pump and make sure the impeller is clear.
Aug 05, 2013 | Pentair Mastertemp Heater
Super 11 pump clogged impeller how to fix
Remove the 6 bolts holding the motor mounting plate to the pump housing. Back the motor assembly out. Remove the diffuser and you'll see the impeller. Using picks and wire run through all of the impellers vanes to clear out the debris.
Mar 19, 2013 | Hayward 3/4hp Super Pump Inground Pool...
Low preusre
If the pump basket is clean and there are no suction leaks, the problem may be that debris has gotten past the pump basket and is clogging the impeller.
A quick way to check is to fill the pump pot (where the basket goes) with water. Leave the lid off and start the pump. The water should be sucked out immediately.
If the water takes more than about half a second to go down you have a clogged impeller and the pump needs to be opened to clear it.
Mar 07, 2013 | Waterway Champion 1 1/2 Hp 230v Energy...
ZODIAC INGROUND POOL PUMP MAKES A NOISE BUT DOES NOT PUMP WATER. WAS WORKING AN YESTERDAY. HAVE CLEANED FILTER, AND MANUALLY TURNED FAN AT THE BACK. STILL NOT WORKING??
If your pool pump is acting sluggish it may simply be a build up of debris inside the impeller. Cleaning it is simple if you know how.
Step 1 - Check the Impeller
You can check the impeller for clogs by opening the clear cover that is on the strainer basket. Then place your garden hose into the basket and turn it on high. The water should disappear immediately. If it does not, you may have a clog.
Step 2 - Turn off the Power to the Pump
Before actually removing the clog from your pool pump impeller you will need to turn off the power to it. Remove the basket and use a finger to reach into the hole behind the basket to feel for any debris. If it is clogged, go to step 3.
Step 3 - Disconnect the Pump and Motor
Disconnect the pump and motor from the plumbing. Depending upon the make and model of your pool pump you may be able to skip this step. The motor usually just slides away from the pump.
Step 4 - Remove the Plastic Cover
Take the pump apart by removing the plastic cover over the motor. This cover generally has several small screws holding it on.
Step 5 - Remove and Clean the Impeller
Once the cover is removed you will easily be able to see the clog in the pool pump impeller. Just use your fingers or a coat hanger to clean it out.
Step 6 - Clean
Put everything back together. Once you have it cleaned out you can put the cover back on and put it all back together. Problem solved.
Dec 10, 2010 | Plumbing
It will start out with a good flow then will not pump any water even though it is keeping its prime.
You have some debris floating around somewhere. If you are pumping from a pond or a rain-barrel, you might have debris clogging the inlet. Or maybe you have a stone in the impeller - if your outlet is on top of the impeller a stone will sink to the bottom so you could have flow initially, but the stone would be carried up to clog the outlet within a few seconds. Or you might have stone in the hose feeding into the impeller - that stone could roll back down the hose even though you don't loose prime.
Jun 28, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
WATER DOES NOT DRAIN COMPLETELY
Your dishwasher's drain pump is not designed to work until the water is completely drained but rather in sync with the timer. The motor will stop when the timer stops no matter how much water is left inside the machine.
In your case, either of the following is causing the trouble:
  1. There's a part clogging in the drain line.
  2. A debris is caught in the drain pump impeller.
  3. Drain valve is not opening completely.
  4. Worn belt if your washer uses a belt to drive the pump.
Here's the remedy to each of them:
  1. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. The drain pump is usually mounted directly to the motor and attached to the bottom of the dishwasher. Remove the lower rack, the spray arm, and the spray arm support to reach the pump from inside the dishwasher. Look for the wash impeller, which forces the water through the spray arm. Beneath it is the drain impeller, which is similar in size and shape to the wash impeller. Clear the drain impeller from any debris that prevent it from pumping out water properly.
  3. Sometimes the drain valve solenoid or the diverting lever sticks and prevents the dishwasher from draining properly. Lubricate the lever to free it up. Replace it otherwise.
  4. If your machine uses a belt to drive the pump, the belt may have been worn and cannot drive the pump properly. Replace the belt if that is the case.
Feel free to give updates.
Dec 01, 2009 | Maytag Dishwashers
Spa - Low water flow
Split the pump. if you don't have a leaf/pump basket then your pump inpeller is propably dirty, you'll need a very thin screwdriver to clean the holes inside the impeller
Jan 02, 2009 | Pool & Spa
Water not getting to the upper level, dishes not cleaned.
Penrod, sounds like a circulation problem. Two things to check first. make sure the upper spray arm is not clogged with debris or split. Second is to twist and remove the filter and clear out any debris where the water enters the circulation pump impeller. If something has jammed the impeller, you would have to remove the dishwasher, remove the tank, remove the circulation motor and clean out the impeller...Catriver...post back.
Sep 03, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Pentair Superflo 1 12 Hp Swimming Pool Pump 340039 Logo
133 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
