Question about Garden
Honda 5.5 engine gas runs out of air cleaner?
  • 252 Answers
Hi there rimler2001
could be carb flooding- check that fuel needle valve is shutting off fuel properly and float has no holes and is clean and set to correct fuel level , - could be debris in the tank - clean out tank and fuel lines
is the air filter wet with fuel ? and does the engine not seem to run properly has a low exhaust note that seems muffled then check for blocked muffler
cheers pauly46
Posted on May 29, 2011
I am getting gas In the crankcase. engine back fires run only with choke out
float is stuck, bad needle and seat, debris between needle and seat and check air cleaner made sure it not oil or fuel soaked even if dry replace
Sep 18, 2014 | Honda Horizontal Engine 5 HP OHC 3/4 x...
Engine will not start
Spray some either into the air filter. If it starts and runs for a few seconds then it is not getting fuel. If it won't start it may be getting too much fuel. Verify that there are no vacuum leaks and that the bowl of the carb has gas in it.
Apr 13, 2014 | Honda Horizontal OHV Engine 270cc, GX...
Why do my car stalls when i let go of the gas coming to a stop
Could be a problem with the idle air control valve or a dirty throttle body.
Sep 18, 2012 | 1994 Honda Civic
1996 honda accord rough idle and dies
Do the following
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Aug 18, 2017 | 1996 Honda Accord
My honda CH-50 metropolitan scooter isn't getting gas from the tank, our friend drove it all around florida and then brought it up to us, we think he flipped a fuel cutt of switch when he shipped
The problem is most likely a blockage in the carb, or air filter. check the air filter and then clean the carb. You may just need to run some fuel system cleaner through the engine, you can do this at idle.
Jun 15, 2012 | Honda Motorcycles
Honda 5hp stationary engine blows milky oil in to air cleaner
It sounds like a combination of too much oil AND moisture in the oil. Completely drain it and replace the oil. Run it for 5 minutes and replace the oil AGAIN.
Feb 04, 2012 | Air Tools & Compressors
87 325 runs good when
It's the automatic choke!
The choke is "closed" or barely open... When cold, the engine needs a RICH mixture (more gasoline, less air). When the engine warms up, it requires a LEAN mixture (less gas, more air).
It is probably creating BLACK tailpipe smoke ... that means unburnt gasoline. (Blue smoke is OIL, white smoke is WATER).
Put the parking / emergency brake ON.
1. Remove air cleaner assembly from intake, use a carb cleaner spray or throttle body spray cleaner and spray just a little. (AutoZone $5)
2. Find the accelerator2.gif arm under the hood.
3. start car, rev the engine to make sure how to operate the accelerator from under the hood.
4. Carefully spray into carb / throttle body and work the accelerator ... don't let the engine die...
5. Watch out for "backfire"... it may create a small flame out of the carb. It will extinguish itself in one second.
6. You may need to do this two, three times.
7. Add a "complete fuel system2.gif cleaner" to your next tank of gas ($8).
That's it! ... pretty cheap, too.
Hope this helps!
Sep 04, 2009 | 1987 BMW 3 Series
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
91 honda accord cut off
Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Apr 06, 2009 | 1991 Honda Accord
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
