Question about Toro Garden
My 6.5 Toro Tecumsek lawn mower Runs too fast. I just cleaned the carb bowl, changed filter and spark plug. It start immediately but runs so fast I am afraid I will blow up the engine. I suspect it is the spring and linkage..... HELP
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
SOURCE: Troy Bilt model 542(11a-542-q711)has Honda 160cc
I need Gaskets for caboretor
Posted on Sep 08, 2009
  • 4 Answers
computerscot is right. This engine is not designed to run slower than a few hundred RPM below maximum. The carb has a built-in fuel pump that only operates properly at relatively high speed. Your motor probably has either missing or weak throttle springs which will lower the RPM. Replace them and adjust the tension so that the speed is up. For a diagram of the carb and springs, check the Briggs & Stratton online user manual maintenence section. Look for file "briggsandstrattonMS5373-GB.pdf".
Posted on Oct 30, 2009
rycgl
  • 1545 Answers
SOURCE: Bolens MTD push mower with B&S 4.5HP
This is probably not a blown gasket issue. A bad head gasket can allow oil to enter the cylinder head/combustion chamber if it's not sealing off the valve area. A simple suggestion is to check on the engine opposite the carb side for the oil/crankcase breather. It will have 2 screws holding it onto the block. It has a type of filter media in it that traps excessive oil and oil vapors from the engine. It is also connected by a tube to the air filter housing. When you tipped, you probably put too much oil in the breather and it was inducted over to the air filter/carb intake side.
Clean or replace the breather after checking it and also make sure you haven't overfilled the Briggs with oil and only use SAE 30 in the engine. Muti-viscosity isn't recommended in summer unless you run synthetic, then it is OK.
Please vote on this solution.
Posted on Sep 05, 2010
Testimonial: "Thank you - sounds like excellent advice and I'll sure let you know what I find."
I have a 6.5 hp toro lawn recycle mover , that will start, but will not continue to run but a few seconds
Their's a bowl under the carburetor ,remove gas from tank or pinch gas line and remove ***** under bowl and gas will come out,clean bowl and reinstall and start it up,Trash gets in their,need a inline filter to stop it.Lowe's has them,3 dollars.
Mar 16, 2016 | Toro Power Lawn Mower
My Toro GTS LV195EA 362003C is starting, but not staying running. I cleaned the carb, replaced the spark plug and filter, and have tried to adjust the govenor and bowl nut on carb, but the throttle and...
Engine surge is usually caused by one of two things...
1) a lean condition. Not getting enough fuel.
2) throttle plate shaft in carb is worn. usually clears up when engine is put under a load. You can live with it or replace the carb
Nov 06, 2012 | Toro Lawn Mower With Toro Power Tools
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro 20624 mower runs rough
Remove float bowl from carb. Ensure gas flows with float hanging down. Ensure gas flow stops with float pushed up.. Remove float and meter needle. clean passage way were meter needle is inserted with a bread wrapper wire, with 1 in of plastic peeled off it, wire should be observed behind choke flap when fully inserted thru passage way. Replace float and meter needle. Clean float bowl. Observe float bowl screw, look to see if it has a hole thru it, if so clean with wire. Reinstall float bowl. Try to start.
Jun 17, 2012 | Toro Garden
I have a Toro 20462 power mower -- about 15 years old, but until just today still running great! The spark plug is good, the gas is good, the oil is good the air filter is good. After priming, it starts...
Remove and clean the brass bolt that holds the float bowl on the carburetor. Clean out the bowl too. Use no metal objects to clean this bolt. It has 3 small holes...bottom...and on the sides near the top. Use carb/choke aerosol spray cleaner on it. IT can clog (esp. without an inline fuel filter on mower). Clean the bolt good, reinstall (not forgettting felt gasket between IT and the bowl) and your runnability problem and fuel flow problem should be solved as the bolt is also the main jet of the carburetor.
Sep 11, 2011 | Toro Power Lawn Mower
Laid mower on right side towards spark plug fixed fuel line won't start changed spark plug
if turned on side with air filter down check to see if filter is oil soaked if so replace. also carb bowl may have oil in it. clamp fuel line remove bowl nut and drain. will smoke when starts but will clear out
Jul 17, 2010 | Toro Garden
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
Have a Toro GPS5 600 lawnmower. Starts with Choke on, but dies if you move off choke. Also, runs fast and slow when blade engaged. I heard carb for this unit are no longer available. Help
May 16, 2010 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 2 stroke lawn mower won't start
Remove the Carb Bowl and on the bottom of the bowl clean the center of crust gas....
It blocks the gas from getting from the bowl to the inside of the carb.
Caused when gas dry's up in the bowl leaving deposits behind plugging up the works.
AL
Apr 26, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
316 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
